Feature Suggestion: Use spacebar to select/unselect checkmark filenames
lmarkd
It would be nice to have the spacebar be able to select/unselect checkbox by each file. That was you could use the arrow keys to move up and down the list and select/unselect each file. Personally I find using keyboard easier than using the mouse.
Re: Feature Suggestion: Use spacebar to select/unselect checkmark filenames
Strange... Seems to work as your ask about.
I use the arrow keys and the space bar all the time to navigate in MakeMKV on macOS.
