Fixed.dihjaskd wrote: Mon Oct 07, 2024 5:34 pm I run a:
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: <redacted>
Firmware date: 2017-04-18
Highest AACS version: 68
Firmware version: ID22
Is there a way to make it libredrive friendly ?
ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
keaney2023
Hi looking for confirmation if i can use the BU40N on my drive:
Manufacturer: ASUS
Revision: 1.10
Serial number: redacted
Manufacturer: ASUS
Revision: 1.10
No. Read your PM.keaney2023 wrote: Mon Oct 21, 2024 1:57 pm Hi looking for confirmation if i can use the BU40N on my drive:
Manufacturer: ASUS
Revision: 1.10
Is it possible to flash this drive to be able to read UHD Blurays?
I didn't know about this UHD stuff and bought the only Bluray burner in the store.
Actually ... the firmware date looks weired.
Manufacturer: ASUS
Revision: A102
Serial number: [redacted]
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 62
No disc insertedActually ... the firmware date looks weired.
I am trying to upgrade my Asus drive I have had for years also. I am not unfamiliar with flashing. I am looking for the correct tool and target firmware.
Thank you.
Thank you.
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: [Redacted]
Highest AACS version: 77
Read this:msteiiin wrote: Tue Nov 05, 2024 6:21 pm Is it possible to flash this drive to be able to read UHD Blurays?
I didn't know about this UHD stuff and bought the only Bluray burner in the store.Code: Select all
Drive Information OS device name: D: Manufacturer: ASUS Product: SBW-06D2X-U Revision: A102 Serial number: [redacted] Firmware date: 2121-06-28 13:41 Bus encryption flags: 1F Highest AACS version: 62 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959 No disc inserted
viewtopic.php?f=16&t=19634
PM is on its way.Farinhir wrote: Fri Nov 15, 2024 3:18 am I am trying to upgrade my Asus drive I have had for years also. I am not unfamiliar with flashing. I am looking for the correct tool and target firmware.
Thank you.
Drive Information OS device name: F: Manufacturer: ASUS Product: SBW-06D2X-U Revision: 1.10 Serial number: [Redacted] Firmware date: 2017-04-18 Bus encryption flags: 1B Highest AACS version: 77 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8511 Firmware version: ID22 No disc inserted
Thank you so very much, Coopervid. I just tested and it works flawlessly.
Based on the other posts in this thread, I think this should be able to be flashed to support UHD, correct?
OS device name: \Device\CdRom2
Manufacturer: ASUS
Revision: 1.10
Highest AACS version: 61
Firmware version: ID22Re: ASUS SBW-06D2X-U
PM sent.Kudo417 wrote: Thu Nov 28, 2024 1:42 am Based on the other posts in this thread, I think this should be able to be flashed to support UHD, correct?
Drive Information OS device name: \Device\CdRom2 Current profile: BD-ROM Manufacturer: ASUS Product: SBW-06D2X-U Revision: 1.10 Serial number: [redacted] Firmware date: 2017-04-18 Bus encryption flags: 1B Highest AACS version: 61 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8511 Firmware version: ID22
WildInsignia
Good Evening All, I have same model Drive and i was trying to see which f/w i would flash, I have downloaded the asus flasher and the f/w pack..just dont know which one to use.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Also wondering the fact that it says "Drive platform: Pioneer RS8511" dose that mean that its a Pioneer drive?
Thank you for any help.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Yes, it's a Pioneer drive. The old Asus flasher isn't compatible.WildInsignia wrote: Mon Dec 02, 2024 4:05 am Good Evening All, I have same model Drive and i was trying to see which f/w i would flash, I have downloaded the asus flasher and the f/w pack..just dont know which one to use.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
WildInsignia
So with that, i would have to use another flasher then?MartyMcNuts wrote: Mon Dec 02, 2024 9:03 pmYes, it's a Pioneer drive. The old Asus flasher isn't compatible.WildInsignia wrote: Mon Dec 02, 2024 4:05 am Good Evening All, I have same model Drive and i was trying to see which f/w i would flash, I have downloaded the asus flasher and the f/w pack..just dont know which one to use.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
There is no public flasher tool available for Pioneer drives. You could try contacting Billycar11. He may be able to do something for you.WildInsignia wrote: Mon Dec 02, 2024 11:19 pmSo with that, i would have to use another flasher then?MartyMcNuts wrote: Mon Dec 02, 2024 9:03 pmYes, it's a Pioneer drive. The old Asus flasher isn't compatible.WildInsignia wrote: Mon Dec 02, 2024 4:05 am Good Evening All, I have same model Drive and i was trying to see which f/w i would flash, I have downloaded the asus flasher and the f/w pack..just dont know which one to use.
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
could you help me out on that one? Thank you!
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: 1.10
Serienummer: [redacted]
Firmware-Datum: 2017-04-18
Highest AACS version: 70
