Can't read AACS VID from disc - most likely current AACS host certificate is drive - Error
dinesh
#1 Post by dinesh » Thu Mar 16, 2023 8:20 am
I am using a Bluray drive called: archgon Star UHD External 4K-Ultra HD BD Player.
I have succesfully ripped a few Bluray movies, but when I tried doing the same for a 4K UHD bluray version, I found the following error:
MakeMKV v1.17.3 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\DineshMuniandy/.MakeMKV/MKB20_v66_Schindler's_List_C1BD.tgz
Please could someone kindly help me with this ? Is there something wrong with my Bluray drive ? Or am I missing any steps ?
Thanks for the help.
dinesh
Re: Can't read AACS VID from disc - most likely current AACS host certificate is drive - Error
#3 Post by dinesh » Fri Mar 17, 2023 9:15 am
Thanks very much for sharing the above - really interesting to go through :)
Ranger_Walker
#4 Post by Ranger_Walker » Thu Jul 27, 2023 11:54 pm
The LibreDrive seems the solution that i'm looking for. How can I install this software?
#5 Post by Woodstock » Fri Jul 28, 2023 12:09 am
LibreDrive is how MakeMKV talks to the drive's BIOS. If you're using MakeMKV, and the drive supports LibreDrive, "it's installed".
coonwhiz
#6 Post by coonwhiz » Fri Jul 28, 2023 6:19 pm
I'm getting similar errors, and as far as I can tell, I have LibreDrive Enabled. Or at least MakeMKV is telling me that I do...
Firmware version: 1.03
markthemoviefan
#7 Post by markthemoviefan » Tue Aug 01, 2023 1:35 am
I'm getting similar results trying to rip The Martian - Extended Edition. I'm using a new BP60NB10 flashed to 1.02. Drive info shows it's LibreDrive Enabled, but getting the following error on attempting...
Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive...
Here's the info...
OS device name: E:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: <removed>
Firmware date: 2120-05-07 09:35
Highest AACS version: 76
Firmware version: 1.02
I've reviewed other posts referencing similar errors without resolution. Any help is greatly appreciated.
Yakk_
#8 Post by Yakk_ » Tue Aug 01, 2023 4:25 pm
I'm getting the same issue. I've ripped a few dozen owned UHD titles, but then started getting this error when I started on disc 2 of the Game of Thrones UHD set. This error persists with every disc I try now. I'm still reading up on the various posts regarding this issue, but I'm a little at a loss right now, haha. Here's the info from MakeMKV v1.17.4, linux version.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.01
Serial number: [redacted]
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8E21
Firmware version: 1.01/ID05
#9 Post by Billycar11 » Tue Aug 01, 2023 5:28 pm
Yakk_ wrote: Tue Aug 01, 2023 4:25 pm I'm getting the same issue. I've ripped a few dozen owned UHD titles, but then started getting this error when I started on disc 2 of the Game of Thrones UHD set. This error persists with every disc I try now. I'm still reading up on the various posts regarding this issue, but I'm a little at a loss right now, haha. Here's the info from MakeMKV v1.17.4, linux version.
Revision: 1.01
Try deleting your privatedata.tar and see if it will redownload
OrsonWellsActually
#10 Post by OrsonWellsActually » Wed Aug 02, 2023 1:57 am
I'm having the same issue. Got a BP60NB10 and flashed it (on Mac) following the steps on the Ultimate Guide
Here's my info...
OS device name: /dev/rdisk4
Revision: 1.02
Firmware date: 2121-07-08 15:56
Highest AACS version: 78
Harware support: Yes
Firmware support: No
The first UHD I tried was the Raging Bull 4K from Criterion, but I got the same error codes:
Regular blu-rays work fine, but now it won't read any UHDs. Any help would be GREATLY appreciated and thanks for the great work you folks are doing here
#11 Post by MartyMcNuts » Wed Aug 02, 2023 3:56 am
OrsonWellsActually wrote: Wed Aug 02, 2023 1:57 am I'm having the same issue. Got a BP60NB10 and flashed it (on Mac) following the steps on the Ultimate Guide
Here's my info...
Revision: 1.02
You haven't flashed it. (see above in red). When flashed under LibreDrive Information it will say Status: Enabled and Firmware type: Patched (microcode access re-enabled)
OrsonWellsActually
#12 Post by OrsonWellsActually » Wed Aug 02, 2023 3:59 pm
Ok should I be using an encrypted firmware? Where do I get that from?
I have an LG BP60NB10 running on MacBook M1
Sorry for all the questions and thank you so much for your help
#13 Post by MartyMcNuts » Thu Aug 03, 2023 12:17 am
OrsonWellsActually wrote: Wed Aug 02, 2023 3:59 pm Ok should I be using an encrypted firmware? Where do I get that from?
If it is a new BP60NB10 with SVC NB12, simply flash it to BP60NB10-NB12 1.02-MK and you are done. If it is not SVC NB12, flash it with BP60NB10 1.02-MK. If you are using the command line, make sure you replace the word "main" with "enc" (no quotes)
Ekontos
#14 Post by Ekontos » Fri Nov 15, 2024 1:42 am
How do you generate the drive info screens with all of the current firmware settings?
#15 Post by MartyMcNuts » Fri Nov 15, 2024 2:04 am
Ekontos wrote: Fri Nov 15, 2024 1:42 am How do you generate the drive info screens with all of the current firmware settings?
Huh??
