ASUS SBW-06D2X-U
n0dna
Re: ASUS SBW-06D2X-U
Post by n0dna »
Any chance I could get a copy as well?
OS device name: /dev/rdisk4
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: [redacted]
Firmware date: 2017-04-18
Highest AACS version: 68
Firmware version: ID22
Thanks so much!
DJNachos wrote: Sun Oct 27, 2024 7:47 pm Hello, I am also wondering if this particular drive has a patch available for 4k UHD discs please; if not thank you for your time regardless.
OS device name: O:
Manufacturer: ASUS
Revision: 1.10
Serial number:
Highest AACS version: 76
PM sent.
n0dna wrote: Thu Nov 14, 2024 10:38 pm Any chance I could get a copy as well?
Manufacturer: ASUS
Revision: 1.10
Thanks so much!
PM sent.
n0dna
Post by n0dna »
Thanks, Coopervid!
Worked perfectly!
DJNachos
Post by DJNachos »
Coopervid wrote: Fri Nov 15, 2024 10:26 am
OS device name: O:
Manufacturer: ASUS
Revision: 1.10
Serial number:
PM sent.
Flashing process went flawlessly; thank you for taking the time to assist.
bernard301
Post by bernard301 »
sorry to jump on, but could you also send details of how to flash this drive:
OS device name: /dev/rdisk5
Manufacturer: ASUS
Revision: 1.10
Highest AACS version: 36
bernard301 wrote: Sat Nov 16, 2024 8:30 pm sorry to jump on, but could you also send details of how to flash this drive:
Manufacturer: ASUS
Revision: 1.10
PM sent.
maximizzar
Post by maximizzar »
Hello, I am also unable to get LibreDrive Mode enabled. Can someone help me please?
Thanks in advance, below is the Drive Information:
OS device name: /dev/sr0
Manufacturer: ASUS
Revision: 1.10
Highest AACS version: 81
maximizzar wrote: Tue Feb 11, 2025 7:38 pm Hello, I am also unable to get LibreDrive Mode enabled. Can someone help me please?
Manufacturer: ASUS
Revision: 1.10
Email me that info see below for email and price
pabrognara
Post by pabrognara »
Coopervid wrote: Mon Oct 07, 2024 6:56 pm Check your PM.
Hi Coopervid, may you inform ur email add? I am still not able to send PM to request 06D2X upgrade. Thanks!!
pabrognara wrote: Wed Jul 09, 2025 3:09 pm
Please post your Makemkv info for your drive. Then you will receive a PM with instructions.
pabrognara
Thanks Cooper, here it goes
Manufacturer: ASUS
Revision: A102
Serial number: MOBNA5G5841
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
pabrognara wrote: Wed Jul 09, 2025 6:42 pm Thanks Cooper, here it goes
Manufacturer: ASUS
Revision: A102
That's an LG drive you can flash with SDFTool flasher. I guess it's a slim. If so flash to BU40N 1.03 MK.
viewtopic.php?f=16&t=19634
mjrgr8pain
Post by mjrgr8pain »
I tried everything and was unable to get the drive to flash with the LG parameters like said above
OS device name: G:
Manufacturer: ASUS
Revision: A102
Serial number:
mjrgr8pain wrote: Fri Jul 11, 2025 12:41 am I tried everything and was unable to get the drive to flash with the LG parameters like said above
OS device name: G:
Manufacturer: ASUS
Revision: A102
Serial number:
It's an LG. Use SDFTool flasher.
