Hello everyone,
I bought a used Dunkirk 4K HDR set off of the Bay. The disc seems to be in what is considered "pristine" condition.
When I try to rip it with my BH16NS55 it fails at roughly 40% of the disc size with one corrupt source file at several offsets.
The source file '/BDMV/STREAM/00019.m2ts' is corrupt or invalid at offset 29113767936, attempting to work around
I tried a competitors product DeUHD and the file 00019.m2ts is able to be ripped and played on VLC. What am I doing wrong in MakeMKV? Is this a problem with HDR content? (Note: I don't mean to trashtalk MakeMKV by comparing it to another product. I was just trouble shooting)
I have ripped Captain Marvel in 4K which has SDR but it ripped just fine. I don't have any other 4K+HDR discs atm.
Thank you guys and stay healthy.
VicTh0r
Dunkirk (UK release)
- Dunkirk_MakeMKV_error.PNG (168.66 KiB) Viewed 12127 times
nick.campbellbro
Re: Dunkirk (UK release)
Hi, did you ever fix this problem? I've got exactly the same drive BH16NS55 and the same thing happens with Dunkirk UHD. Not sure if I need to try a different disc or drive
Possibly but have you tried cleaning the disc first? If not, do so before trying to rip it again.nick.campbellbro wrote: Wed Nov 13, 2024 3:52 pm Hi, did you ever fix this problem? I've got exactly the same drive BH16NS55 and the same thing happens with Dunkirk UHD. Not sure if I need to try a different disc or drive
nick.campbellbro
yeah, i've tried cleaning it. i originally took it freshly out the wrapping straight into the drive. you wouldnt think it could be dirty.Possibly but have you tried cleaning the disc first? If not, do so before trying to rip it again.
i tried again and i get the following errors:
DEBUG: Code 1 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 2 at >{`y(>CqW-`Fca0ypbVz:29394758
The source file '/BDMV/STREAM/00019.m2ts' is corrupt or invalid at offset 29525944320, attempting to work around
DEBUG: Code 3 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 4 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 5 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 6 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 7 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 8 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 9 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 10 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 11 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 12 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 13 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 14 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 15 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 16 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 17 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 18 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 19 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 20 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 21 at >{`y(>CqW-`Fca0ypbVz:29394758
Hash check failed for file 00019.m2ts at offset 29525993472, file is corrupt.
DEBUG: Code 22 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 23 at >{`y(>CqW-`Fca0ypbVz:29394758
The source file '/BDMV/STREAM/00019.m2ts' is corrupt or invalid at offset 29526011904, attempting to work around
DEBUG: Code 24 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 25 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 26 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 27 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 4113 at >{`y(>CqW-`Fca0ypbVz:213131663
DEBUG: Code 28 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 29 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 30 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 31 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 32 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 33 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 34 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 35 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 36 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 37 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 38 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 39 at >{`y(>CqW-`Fca0ypbVz:29394758
The source file '/BDMV/STREAM/00019.m2ts' is corrupt or invalid at offset 29526061056, attempting to work around
DEBUG: Code 40 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 41 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 42 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 43 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 44 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 45 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 46 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 47 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 48 at >{`y(>CqW-`Fca0ypbVz:29394758
Hash check failed for file 00019.m2ts at offset 29526190080, file is corrupt.
DEBUG: Code 0 at >{`y(>CqW-`Fca0ypbVz:121262831
DEBUG: Code 0 at >{`y(>CqW-`Fca0ypbVz:121263153
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:213131157
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:213131272
DEBUG: Code 14416998 at MUklj]%J8Q@ \s=`g8hm:121261773
DEBUG: Code 0 at hijnaX{Xh8"!jVD5f:tCE:213129984
DEBUG: Code 0 at r*4xP~>k4SvZ3d8pxZ:2I:121268972
DEBUG: Code 1 at ^zxXn;o<9_KZZXF@:213132537
Failed to save title 2 to file K:/Videos/Movies/Dunkirk_t02.mkv
Encountered 2 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed-
nick.campbellbro
So...just in case anyone cares. I bought a Pioneer BDR-UD04 and all worked fine with no errors.
Either the BH16NS55 doesn't like Dunkirk 4k (and I had a similar problem with The Dark Knight Rises 4k) or it is on it's way out
It has been my experience that some drives just don't like some discs. This is why I'm up to 4 different drives sitting on my desk. It is very rarely that a disc can't be read by at least one of my drives (and usually one of my Pioneer drives).nick.campbellbro wrote: Wed Nov 20, 2024 11:54 pm So...just in case anyone cares. I bought a Pioneer BDR-UD04 and all worked fine with no errors.
