Dunkirk (UK release)
VicTh0r
#1 Post by VicTh0r » Mon Apr 27, 2020 1:03 pm
Hello everyone,
I bought a used Dunkirk 4K HDR set off of the Bay. The disc seems to be in what is considered "pristine" condition.
When I try to rip it with my BH16NS55 it fails at roughly 40% of the disc size with one corrupt source file at several offsets.
The source file '/BDMV/STREAM/00019.m2ts' is corrupt or invalid at offset 29113767936, attempting to work around
I tried a competitors product DeUHD and the file 00019.m2ts is able to be ripped and played on VLC. What am I doing wrong in MakeMKV? Is this a problem with HDR content? (Note: I don't mean to trashtalk MakeMKV by comparing it to another product. I was just trouble shooting)
I have ripped Captain Marvel in 4K which has SDR but it ripped just fine. I don't have any other 4K+HDR discs atm.
Thank you guys and stay healthy.
VicTh0r
nick.campbellbro
Re: Dunkirk (UK release)
#2 Post by nick.campbellbro » Wed Nov 13, 2024 3:52 pm
Hi, did you ever fix this problem? I've got exactly the same drive BH16NS55 and the same thing happens with Dunkirk UHD. Not sure if I need to try a different disc or drive
#3 Post by MartyMcNuts » Wed Nov 13, 2024 11:30 pm
nick.campbellbro wrote: Wed Nov 13, 2024 3:52 pm Hi, did you ever fix this problem? I've got exactly the same drive BH16NS55 and the same thing happens with Dunkirk UHD. Not sure if I need to try a different disc or drive
Possibly but have you tried cleaning the disc first? If not, do so before trying to rip it again.
nick.campbellbro
#4 Post by nick.campbellbro » Thu Nov 14, 2024 6:03 pm
yeah, i've tried cleaning it. i originally took it freshly out the wrapping straight into the drive. you wouldnt think it could be dirty.
i tried again and i get the following errors:
DEBUG: Code 1 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 2 at >{`y(>CqW-`Fca0ypbVz:29394758
The source file '/BDMV/STREAM/00019.m2ts' is corrupt or invalid at offset 29525944320, attempting to work around
DEBUG: Code 3 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 4 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 5 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 6 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 7 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 8 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 9 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 10 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 11 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 12 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 13 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 14 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 15 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 16 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 17 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 18 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 19 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 20 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 21 at >{`y(>CqW-`Fca0ypbVz:29394758
Hash check failed for file 00019.m2ts at offset 29525993472, file is corrupt.
DEBUG: Code 22 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 23 at >{`y(>CqW-`Fca0ypbVz:29394758
The source file '/BDMV/STREAM/00019.m2ts' is corrupt or invalid at offset 29526011904, attempting to work around
DEBUG: Code 24 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 25 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 26 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 27 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 4113 at >{`y(>CqW-`Fca0ypbVz:213131663
DEBUG: Code 28 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 29 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 30 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 31 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 32 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 33 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 34 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 35 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 36 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 37 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 38 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 39 at >{`y(>CqW-`Fca0ypbVz:29394758
The source file '/BDMV/STREAM/00019.m2ts' is corrupt or invalid at offset 29526061056, attempting to work around
DEBUG: Code 40 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 41 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 42 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 43 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 44 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 45 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 46 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 47 at >{`y(>CqW-`Fca0ypbVz:29394758
DEBUG: Code 48 at >{`y(>CqW-`Fca0ypbVz:29394758
Hash check failed for file 00019.m2ts at offset 29526190080, file is corrupt.
DEBUG: Code 0 at >{`y(>CqW-`Fca0ypbVz:121262831
DEBUG: Code 0 at >{`y(>CqW-`Fca0ypbVz:121263153
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:213131157
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:213131272
DEBUG: Code 14416998 at MUklj]%J8Q@ \s=`g8hm:121261773
DEBUG: Code 0 at hijnaX{Xh8"!jVD5f:tCE:213129984
DEBUG: Code 0 at r*4xP~>k4SvZ3d8pxZ:2I:121268972
DEBUG: Code 1 at ^zxXn;o<9_KZZXF@:213132537
Failed to save title 2 to file K:/Videos/Movies/Dunkirk_t02.mkv
Encountered 2 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
It did let me backup the disc, but it said 00019.m2ts had over 10 HashCheck Errors
nick.campbellbro
#5 Post by nick.campbellbro » Wed Nov 20, 2024 11:54 pm
So...just in case anyone cares. I bought a Pioneer BDR-UD04 and all worked fine with no errors.
Either the BH16NS55 doesn't like Dunkirk 4k (and I had a similar problem with The Dark Knight Rises 4k) or it is on it's way out
#6 Post by dcoke22 » Fri Nov 22, 2024 5:11 pm
nick.campbellbro wrote: Wed Nov 20, 2024 11:54 pm So...just in case anyone cares. I bought a Pioneer BDR-UD04 and all worked fine with no errors.
It has been my experience that some drives just don't like some discs. This is why I'm up to 4 different drives sitting on my desk. It is very rarely that a disc can't be read by at least one of my drives (and usually one of my Pioneer drives).
