LV8HD
Post by LV8HD » Fri Nov 01, 2024 11:25 am
RESET_9999 wrote:
Tue Oct 29, 2024 5:10 pm
LV8HD wrote:
Tue Oct 29, 2024 4:48 pm
@RESET_9999 in the most recent update you introduced the possibility to measure brightness of an HDR10 video on a frame-by-frame basis, which, to me, seems the most correct approach. Does this mean the MadVR method is less accurate even with excluded letterboxes? does it work on a scene-by-scene basis?
good catch haha. I didn't mention it in the release note because it's soooooo slow that it's unusable. I practically wasted my time on this code but it is indeed a frame by frame analysis / plotting. It uses the same script that generates the maxcll/fall stats in (7-2) (7-1).
Madvr analysis is also frame by frame but because I use Dovi_tool to plot the data, the graph is shot by shot. It's still 100% accurate but the values are rounded shot by shot. MadVR overall should be more accurate too since it measure pixels perceptually while the other script just measures the pixels as they are without any restriction.
I see. Correct me if I'm wrong. MadVR measures pixels using perceptual quantization while the other script the raw data?
Post by RESET_9999 » Fri Nov 01, 2024 12:04 pm
right
LV8HD
Post by LV8HD » Sat Nov 02, 2024 5:03 pm
@RESET_9999 pushed by curiosity I decided to check what the fastest method of measuring HDR with excluded letterboxes was on my PC (MKV measurement vs. Cropped ProRes measurement). The winner ended up being MKV although I have a good CPU (AMD Ryzen 7 7700x), but that's not the point.
As soon as both measurements were done (same movie) I took a look at them expecting to see the same results, however, they differed of a couple of nits. Why is that?
MKV measurement
ProRes measurement
Post by RESET_9999 » Sat Nov 02, 2024 6:45 pm
prores encode probably change the grain structure a little bit so small variation like that is normal
Thats surprising. On my i9 13900ks it's almost two times faster with prores.
daffie
Post by daffie » Tue Nov 05, 2024 10:57 am
kazuma wrote:
Thu Oct 31, 2024 5:17 pm
reset_9999, how did you find the PQ of the tenant with cm4.0?
Hi, how do you watch ''with cm4.0'' ?
By using the CPM build with the AM6B+ ?
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
TheEqualizer
Post by TheEqualizer » Tue Nov 05, 2024 10:50 pm
RESET_9999 wrote:
Wed Oct 16, 2024 7:28 pm
maybe, I dont know. You can also demux with tsmuxer
I've done all sorts of tests with this German edition of the movie "Late Night with the Devil". I used mkvtoolnix, dovi_script, DGDemux, MakeMKV, the first three have a similar output, the last one does not output correctly, but if you compare the scene-cuts of all the options, but they do not match the scene-cuts of the EL layer extracted using tsMuxeR, does this mean that technically remux mkv 7Profile is not allowed?
EL_scene-cuts
MKVToolNix_DoVi-Script_DGDemux_scene-cuts
https://i.ibb.co/KrX9cbG/EL-PLOT.png
https://i.ibb.co/VBs1t5h/ST-DL-PLOT.png
Post by RESET_9999 » Wed Nov 06, 2024 12:52 am
I dont know. I watched this one in Profile 8 without EL and everything was fine.
TheEqualizer
Post by TheEqualizer » Wed Nov 06, 2024 5:40 am
I'll tell you more, those who have already watched the remux in mkv 7p also did not see anything suspicious, so in the question I pointed out that technically it is still not correct and it is not allowed to make such remuxs. Perhaps if a British UHD appears, things will be better on it.
Post by RESET_9999 » Wed Nov 06, 2024 11:30 am
i dont know but my p8 remux is perfectly in sync with the BL scene cuts
Post by RESET_9999 » Fri Nov 08, 2024 10:25 pm
I had another look at this movie and indeed a P7 mux with dovi_tool or mkvtoolnix is still wrong.
The RPU extracted from tsmuxer demuxed hevc is fine though so a P8 rip works.
valington
Post by valington » Sat Nov 09, 2024 10:18 am
maybe try to do this film in TS container and it will be proper in ts muxer
Post by RESET_9999 » Sat Nov 09, 2024 1:50 pm
tsmuxer doesn't support ST-DL authoring.
anyway the problem is the EL and german discs
daffie
Post by daffie » Tue Nov 12, 2024 1:42 pm
I have a profile 7 mkv of this movie - is there a way to make a P8 rip from it while keep all the EL data ?
Not with this German disc I guess?
Post by RESET_9999 » Tue Nov 12, 2024 7:04 pm
Remove the EL and inject this RPU:
https://drive.google.com/file/d/1urqjRi ... drive_link
daffie
Post by daffie » Thu Nov 14, 2024 8:45 am
Thanks for your help!
Do I need to use workflow 4-1 for this?
