maybe try to do this film in TS container and it will be proper in ts muxerRESET_9999 wrote: ↑Fri Nov 08, 2024 10:25 pmI had another look at this movie and indeed a P7 mux with dovi_tool or mkvtoolnix is still wrong.TheEqualizer wrote: ↑Wed Nov 06, 2024 5:40 amso in the question I pointed out that technically it is still not correct and it is not allowed to make such remuxs. Perhaps
The RPU extracted from tsmuxer demuxed hevc is fine though so a P8 rip works.
tsmuxer doesn't support ST-DL authoring.
anyway the problem is the EL and german discs
I have a profile 7 mkv of this movie - is there a way to make a P8 rip from it while keep all the EL data ?RESET_9999 wrote: ↑Fri Nov 08, 2024 10:25 pmI had another look at this movie and indeed a P7 mux with dovi_tool or mkvtoolnix is still wrong.TheEqualizer wrote: ↑Wed Nov 06, 2024 5:40 amso in the question I pointed out that technically it is still not correct and it is not allowed to make such remuxs. Perhaps
Not with this German disc I guess?
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
Thanks for your help!RESET_9999 wrote: ↑Tue Nov 12, 2024 7:04 pmRemove the EL and inject this RPU:
https://drive.google.com/file/d/1urqjRi ... drive_link
Do I need to use workflow 4-1 for this?
Thanks alot. I managed to convert it to profile 8 and was able to watch it without problem!
TheEqualizer
About the movie Late Night with the Devil, I checked the new GBR edition, everything is fine with it, I'm doing a remux mkv 7 Profile.
darrrkmanxxx
sorry late to the party but you can do everything on macos, besides the madvr measureing.ans40 wrote: ↑Mon Oct 21, 2024 9:31 pmI'm not sure about Mac options, but you could use the tools with a Windows virtual machine, too.Jimbo21 wrote: ↑Mon Oct 21, 2024 9:31 amHi all
Does anyone know if there is a Mac app that converts HDR10+ to Dolby Vision?
Have used Nekno's "DV7 to DV8" MacOS app (as the name implies, to convert DV7 to DV8). It works well. But am trying to find something for HDR10+ to DV. Have seen Reset's DoVi scripts, but unfortunately don't have Windows.
- extract hevc file from the container with Tsmuxer
- extract the hdr10+ json from the hevc with: https://github.com/quietvoid/hdr10plus_tool
- convert to dvp8 rpu with: https://github.com/quietvoid/dovi_tool look for From an existing HDR10+ metadata JSON file
- adjust CMv4.0 and L5 Active area if not OpenMatte, see https://github.com/quietvoid/dovi_tool look for editor with data from MedIaInfo (see Mastering display luminance etc.)
- mux back the new dvp8.hevc files into the container with MKVToolsnix
hdr10plus_tool, dovi_tool, MKVToolnix and TsMuxeR are working native on macOS
ColonelBlimp043
If I run 3-1 to generate a new RPU for a profile 7 FEL MKV with static metadata, will the FEL be analyzed together with the BL by CM Analyzer?
I tried bake encoding the BL+FEL into a ProRes .mov with 8-2 and then running 3-1 on the resulting ProRes .mov, but I received an error message that the ProRes file was not HDR.
No, 3-1 doesnt bake FEL.If I run 3-1 to generate a new RPU for a profile 7 FEL MKV with static metadata, will the FEL be analyzed together with the BL by CM Analyzer?
You'll probably have to provide the shot list. If the original static RPU has proper scene cuts, just rename it the same as your prores file and try 3-1 again.I tried bake encoding the BL+FEL into a ProRes .mov with 8-2 and then running 3-1 on the resulting ProRes .mov, but I received an error message that the ProRes file was not HDR.
If the original has no scene cut, you can try to add ''transfer=hdr matrix=2020'' in your prores filename but I'm not sure if generating new scene cuts for FEL is right because of the reshaping metadata.
ColonelBlimp043
Thanks. Even if I successfully run 3-1 on the baked pro-res file, though, is there any way to inject the generated RPU into the original profile 7 FEL mkv? As I understand workflow 1’s inject function, it would discard the FEL video track and create a profile 8 mkv with the BL and new rpu.
Essentially, I want to mux the new rpu with original BL and EL video tracks.
You have to transfer the generated metadata levels to the original P7 RPU with workflow 2-3. You'll have to transfer levels 12389 but you may have to transfer 12 and then 389(I'm not sure if 12389 will work).
If you didn't use the original scene cuts, you have to transfer them too but as I said earlier I'm not sure it is right to change the original FEL scene cuts.
Then you can inject the new P7 RPU to the original P7 mkv rip with workflow 1
ColonelBlimp043
Thanks. I genuinely appreciate the help. This is only a problem on a handful of FEL rips with static/missing metadata. Criterion seems to be the worst offender as a publisher, and the recent Cameron releases also have static trims. Thankfully they all seem to be mastered at low nit levels and don’t use the FEL to raise brightness, so this may all be academic.
I wonder if all the French UHD-BD should be verified now. It looks like Blade 1998 FEL FRA BD has the same issue
https://slow.pics/c/YzYgHn4x
