Ripping Failure - Raging Bull 4K (Criterion Collection)
LordJZS
Post by LordJZS » Tue Nov 05, 2024 6:54 am
I am trying to rip a Criterion Collection 4k version of Raging Bull and get failures at the same spot (Exactly 27385.4M Output File Size ) on two different drives. Asus BW-16D1HT and LG WH16NS60. (These drives are new! Bought within the last 30 Days)
I have emailed criterion for any manufacture defects and they told me they didn't have any issues with the disk and to clean it. (which i have) Just not sure what to do. Drive info is Below. Error is at the bottom. This is the only disk I have had issues with.
Tomorrow I will ask to swap out with another one at the store to see if the disk is just bad.
Drive #1
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: ......
Bus encryption flags: 1F
Highest AACS version: 81
Firmware version: 3.10
Drive #2
Product: BD-RE WH16NS60
Revision: 1.02
Serial number:.......
Firmware version: 1.02
Error(s) I got a bunch of ILLEGAL REQUEST or something like that.
ASUS
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '30610814976'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom1' at offset '30610814976'
Error 'Internal error - Operation result is incorrect (78)' occurred while reading '\Device\CdRom1' at offset '30610814976'
But I cancelled it and then switched to to LG
LG
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '30598496256'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30598496256'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '30604394496'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30604394496'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '30604523520'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '30609113088'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30609113088'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '30609174528'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '30609506304'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30609506304'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '30609506304'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '30609506304'
LordJZS
Re: Ripping Failure - Raging Bull 4K (Criterion Collection)
Post by LordJZS » Thu Nov 14, 2024 6:34 am
UPDATE
I exchanged for a new copy from the store. Ripped just fine.
