Failed to save titles (log file attached)
Neoculture
Post by Neoculture »
I purchased the "Andromeda" box set (5 seasons, 30 disks) and started ripping them to my NAS. The first season (all 5 disks) ripped without a problem. All other seasons had problems - none of the episodes would rip, but the one or two specials in each season did rip. No error messages except for "failed to save". :?
According to the packaging, the first season was packaged by "Beyond Home Entertainment", while the remaining seasons are from "Force Entertainment".
I am using a registered version of MakeMKV (1.6.15 win(x64)), on a HP Pavilion dv6 laptop running Windows 7 Ultimate (x64).
Any thoughts? Thanks.
(note: log file was shortened to only show the first failure, otherwise it was 1.5Mb even when ZIPed)
MakeMKV_log.txt
(794.48 KiB) Downloaded 745 times
Re: Failed to save titles (log file attached)
Post by mike admin »
This is apparent disc mastering error or a new protection. I have to ask you to do a testdump for each episode that fails, per instructions at http://www.makemkv.com/onlinehelp/testdump.html .
Neoculture
Season 2 Episode 1: http://dl.dropbox.com/u/44615354/title00.tgz
Season 2 Episode 2: http://dl.dropbox.com/u/44615354/title01.tgz
Season 2 Episode 3: http://dl.dropbox.com/u/44615354/title02.tgz
Season 2 Episode 4: http://dl.dropbox.com/u/44615354/title03.tgz
As of 2011-10-10@0757UTC, only the first file has loaded into dropbox. The others are still loading. Updates as they load.
UPDATE: 2011-10-12 - All files are loaded in Dropbox.
Neoculture
Damn. I'd hoped that MakeMKV v1.6.16 would fix my problem, but no-go.
It was supposed to. All four titles still fail?
Neoculture
Yes, almost as soon as they start. :(
pauly139
Post by pauly139 »
I am having the same problem with Andromeda Season 2 - 5. Using MakeMKV 1.70
Was there any ever resolution to this problem?
Decibel
Post by Decibel »
As of Version 1.8.3. the same issue is present, Andromeda Season 1 box set will copy, but Season's 2-5 will not.
crowfax
Post by crowfax »
Can you guys all do the testdump that mike linked to above with 1.8.3 please.
Decibel
Post by Decibel »
Attached is the link to teh files for Andromeda Season 2 Disk 1
[hidden]
Regards,
Decibel
crowfax
Post by crowfax »
you need to email it as the instructions instruct.
Decibel
Post by Decibel »
My bad. Email with link has been sent.
Decibel
Post by Decibel »
Has there been any progress after checking the testdump files for Andromeda Season 2 and above
Decibel
Post by Decibel »
Andromeda Season 2 results with MakeMKV 1.8.4
Success. Episodes are now able to be converted to MKV.
A similar message to below was seen for all episodes:
"Saving 1 titles into directory E:/Video/ANDROMEDA_S
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1714176, attempting to work around"
The process did complete successfully.
Keep up the great work with the constant improvements ot teh software.
Decibel
