BDR-XS07S UHD Flash
panzerschrekk
Re: BDR-XS07S UHD Flash
Post by panzerschrekk »
Is this a supported drive? Seems like it, Firmware from 2020 and V 1.01
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: BADL________
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 19
Drive platform: RS8E20
Firmware version: 1.01
Can i dm you Coopervid? Sorry, you'll probably have to dm me
panzerschrekk wrote: Wed Oct 16, 2024 6:32 am Is this a supported drive? Seems like it, Firmware from 2020 and V 1.01
OS device name: F:
Revision: 1.01
PM sent.
panzerschrekk
Coopervid wrote: Thu Oct 17, 2024 9:12 am PM sent.
Thanks alot :)
Dr Zaphod
Post by Dr Zaphod »
My drive information:
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-XD07
Revision: 1.03
Serienummer: xxxx
Firmware-Datum: 2020-08-20
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 81
Drive platform: RS8D30
Firmware version: 1.03
So according to the firmware date I assume it can be patched/cross flashed, correct?
PM would be highly appreciated.
Keep up the great work!
Dr Zaphod
Post by Dr Zaphod »
From my understanding this drive can be flashed?
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: BADLxxxx
Firmware date: 2020-08-20
If this is the case a pm would be highly appreciated. Thank You!
bistl
Post by bistl »
Coopervid, can you send me the instructions please?
Revision: 1.01
Serial number: xxxxxxxxxx
Dr Zaphod wrote: Wed Oct 30, 2024 7:05 am From my understanding this drive can be flashed?
Revision: 1.03
PM sent.
bistl wrote: Tue Nov 12, 2024 2:27 pm Coopervid, can you send me the instructions please?
Revision: 1.01
PM is on its way.
bistl
Post by bistl »
Coopervid wrote: Wed Nov 13, 2024 10:49 am PM is on its way.
Thank you very much!
DaBaDa79
Post by DaBaDa79 »
Hi, as I have the same drive as hydra I would kindly ask if you can send me the instructions as well. Thanks!
DaBaDa79 wrote: Thu Dec 12, 2024 10:40 pm Hi, as I have the same drive as hydra I would kindly ask if you can send me the instructions as well. Thanks!
Post your Makemkv info. I will then send a PM accordingly.
Nadme447
Post by Nadme447 »
I have a Pioneer BDR-XS07TS, would this work with the software fix please, or would I need to get a Pioneer BDR-XS07TUHD, apologies I’m not an expert at this. Thanks
DaBaDa79
Post by DaBaDa79 »
Coopervid wrote: Fri Dec 13, 2024 10:25 am
Of course, here you go:
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-XS07
Revision: 1.01
Serienummer: xxxxx
Firmware-Datum: 2020-09-03
Nadme447 wrote: Sat Dec 14, 2024 5:15 am I have a Pioneer BDR-XS07TS, would this work with the software fix please, or would I need to get a Pioneer BDR-XS07TUHD, apologies I’m not an expert at this. Thanks
Same thing. Post your Makemkv info.
FYI: There are a lot of one time posters who ask for help and then never read their PM to get their drive fixed. This is extremely disappointing. People ask for help, get help and then never check their PMs. That's why I will delete all PMs with help for these people when not read within 14 days. And will not PM again. They need to try to get help elsewhere.
