The Dark Crystal - keep getting errors
sadcaper
Post by sadcaper »
I've tried this a few times now and keep getting read errors. Below are the errors I'm getting:
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '3193171968'?
DEBUG: Code 0 at [*X>{VprB^%VoVS{s0PY:29394298?
DEBUG: Code 0 at <:"B$q[53>inI<g3tSb-:121261681?
DEBUG: Code 0 at [*X>{VprB^%VoVS{s0PY:29394183?
DEBUG: Code 1559166 at [*X>{VprB^%VoVS{s0PY:29393309
?DEBUG: Code 0 at uLz%GR6WvQg)bD5*;|JGa:213134377?
LIBMKV_TRACE: Exception: Error while reading input?Failed to save title 0 to file /Volumes/MartinDrobo/Movies/Videos/Movies/title00.mkv?0 titles saved, 1 failed
?DEBUG: Code 2281701379 at <:t0Gz~y>d}Ti4pu:213133917
Then it just repeats this last line forever.
Thoughts?
Re: The Dark Crystal - keep getting errors
Post by mike admin »
The program can't read the data from the disc, which means either bad disc or drive. Do you get any errors when reading other blu-ray discs?
