Need help: failed to downgrade drive BH16NS40 (f/w 1.03) to WH16NS60 1.02mk
forfrom
#1 Post by forfrom » Mon Nov 11, 2024 10:18 am
MakeMKV v1.17.8 can detect my drive BH16NS40 and can read DVD and bluray disc from it. I want to downgrade its firmware to HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936. After clicking the start button of SDFtool v1.3.5 (with Write Firmware selected), nothing happened no matter whether I selected encrypted or not. I also tried to select other WH16NS60 firmware versions but got the same result: nothing happened. I would be very grateful if someone could help me with this problem.
Product: BD-RE BH16NS40
Revision: 1.03
Serial number:
Firmware date: 2117-11-20 19:43
Highest AACS version: 43
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Other Information
I use a SATA to USB3.0 converter with external power supply to connect the drive to my PC. My drive was manufactured in June 2018.
zittrig
Re: Need help: failed to downgrade drive BH16NS40 (f/w 1.03) to WH16NS60 1.02mk
#2 Post by zittrig » Mon Nov 11, 2024 7:56 pm
A friend of mine had the same problem. Solution was another USB-SATA adapter.
If you get a reaction with the flasher, first flash from original 1.03 to MK 1.03. Then down to MK 1.02.
forfrom
#3 Post by forfrom » Tue Nov 12, 2024 2:50 am
Thanks very much. Do you know the adapter type that your friend is using, e.g. brand name, SATA to USB 2.0? I tried two different adapters (both USB 3.0) but got the same result. In addition, my PC is running Windows 11, would this make difference?
#4 Post by MartyMcNuts » Wed Nov 13, 2024 12:15 am
Read the UHD Guide 2024. It contains a list of drives/enclosures/powered adapters that work.
#5 Post by Coopervid » Wed Nov 13, 2024 10:57 am
This one is cheap and works for flashing. Tested.
https://www.amazon.com/-/de/dp/B07JGT17 ... r=8-1&th=1
forfrom
#6 Post by forfrom » Wed Nov 13, 2024 11:41 am
Thanks to all of you. Since SATA to USB may have problem, I find a friend with >10 years old Win 10 PC. I connected the drive to it through SATA port and had successfully downgraded the drive.
