Need help: failed to downgrade drive BH16NS40 (f/w 1.03) to WH16NS60 1.02mk
forfrom
Post by forfrom » Mon Nov 11, 2024 10:18 am
MakeMKV v1.17.8 can detect my drive BH16NS40 and can read DVD and bluray disc from it. I want to downgrade its firmware to HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936. After clicking the start button of SDFtool v1.3.5 (with Write Firmware selected), nothing happened no matter whether I selected encrypted or not. I also tried to select other WH16NS60 firmware versions but got the same result: nothing happened. I would be very grateful if someone could help me with this problem.
Product: BD-RE BH16NS40
Revision: 1.03
Serial number:
Firmware date: 2117-11-20 19:43
Highest AACS version: 43
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Other Information
I use a SATA to USB3.0 converter with external power supply to connect the drive to my PC. My drive was manufactured in June 2018.
zittrig
Re: Need help: failed to downgrade drive BH16NS40 (f/w 1.03) to WH16NS60 1.02mk
Post by zittrig » Mon Nov 11, 2024 7:56 pm
A friend of mine had the same problem. Solution was another USB-SATA adapter.
If you get a reaction with the flasher, first flash from original 1.03 to MK 1.03. Then down to MK 1.02.
forfrom
Post by forfrom » Tue Nov 12, 2024 2:50 am
Thanks very much. Do you know the adapter type that your friend is using, e.g. brand name, SATA to USB 2.0? I tried two different adapters (both USB 3.0) but got the same result. In addition, my PC is running Windows 11, would this make difference?
Post by MartyMcNuts » Wed Nov 13, 2024 12:15 am
forfrom wrote: Tue Nov 12, 2024 2:50 am Thanks very much. Do you know the adapter type that your friend is using, e.g. brand name, SATA to USB 2.0? I tried two different adapters (both USB 3.0) but got the same result. In addition, my PC is running Windows 11, would this make difference?
Read the UHD Guide 2024. It contains a list of drives/enclosures/powered adapters that work.
Post by Coopervid » Wed Nov 13, 2024 10:57 am
This one is cheap and works for flashing. Tested.
https://www.amazon.com/-/de/dp/B07JGT17 ... r=8-1&th=1
forfrom
Post by forfrom » Wed Nov 13, 2024 11:41 am
Thanks to all of you. Since SATA to USB may have problem, I find a friend with >10 years old Win 10 PC. I connected the drive to it through SATA port and had successfully downgraded the drive.
