BDR-XD08LE Flashing Help
UnusualPositioning
Post by UnusualPositioning » Sun May 05, 2024 3:27 am
Hey all. Super kinda confused about the process of flashing the BDR-XD08 and which files to download where to put them and so on. I have a BDR-XD08LE with a 1.00 firmware that I got off EBay. From my understanding I need to flash it for it to even be able to read 4k UHDs. When I put one in, It reads for a while and then pops open saying, No Disc. Help me out here. What do I download and where do I put it? Thank you very much for any help :D :D :D
Here is the information from MakeMKV
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.00
Serial number:
Firmware date: 2021-03-22
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.00/ID36
Re: BDR-XD08LE Flashing Help
Post by Coopervid » Sun May 05, 2024 10:45 am
Revision: 1.00
Serial number:
Check your PM.
UnusualPositioning
Post by UnusualPositioning » Sun May 05, 2024 12:08 pm
Thank you!!!!!
juniper0
Post by juniper0 » Fri Jun 07, 2024 7:31 pm
Hi!
Sorry to bump this thread, but I've been searching the forums for a way to cross flash this drive and can't find any real info on it. Would you be able to share what you did? PM is totally fine!
Revision: 1.00
Serial number:
Firmware date: 2022-04-03
Highest AACS version: 81
Drive platform: Pioneer RS9330
Firmware version: GENE
GoldenBadger
Post by GoldenBadger » Sat Nov 09, 2024 9:47 pm
I am in a similar situation. Could I ask for a pm with the information on how to flash this drive?
Many thanks,
GoldenBadger
Post by Coopervid » Sun Nov 10, 2024 10:54 am
Many thanks,
GoldenBadger
Post your Makemkv info.
juniper0
Post by juniper0 » Sat Nov 16, 2024 8:29 pm
I could still use help on that too, since I never received a reply after posting my Make MKV info - is there an issue with my drive? thanks :)
Post by MartyMcNuts » Sat Nov 16, 2024 10:16 pm
You really should pm Mike admin and ask him if he can add your firmware version to the libredrive compatibility list. He will tell you if he can and what he needs to do so.
