HP BDRE BU40N Revision BW43: which firmware from the firmwarepack should i flash to?
shisha0505
Re: HP BDRE BU40N Revision BW43: which firmware from the firmwarepack should i flash to?
#16 Post by shisha0505 » Sat Nov 09, 2024 9:48 pm
getting too old?
Well, i am already too old :? :mrgreen:
the enclosure was only 15 €, so cutting/cracking a hole in the backplate isn't much of an issue.
Then with the help of some gaffa tape this will "become a permanent/flexible desk/benchtop fixture" as well... :mrgreen:
Since the drive usually lies on top of the PC hidden under the desk it won't hurt my eyes too much.. :wink: :mrgreen:
PS: just found some simple and cheap USB to Mini-SATA adapters like that one:
https://www.amazon.de/BENFEI-SATA-USB-K ... Caps%2C103
Is there any reason why you bought a much more expensive one?
flojo
#17 Post by flojo » Sat Nov 09, 2024 9:59 pm
I bought one of those USB 3.0 to Slimline SATA a couple years back on Aliexpress and it worked fine to flash 2 of them. Granted, I never tried to actually rip a UHD with it, just flash.
I'd prefer the adapter d00zah linked to because you can use just about any 12v power adapter. I have several of those kits, even one dating back to like 2001 and they all still work fine, but I don't have the original power adapter for any of them. I bought 5 of the kits for 30usd once just for the itty-bitty sata cable/adapter included with them, they're handy if you use a sub-iTX form factor.
shisha0505
#18 Post by shisha0505 » Sat Nov 09, 2024 10:03 pm
is there any reason why someone would want an adapter with a power supply?
Afaik usually USB3 should be able to supply the drive with enough power.
#19 Post by Billycar11 » Sat Nov 09, 2024 10:06 pm
Get one with a psu desktop drives will never be powered off USB and if its a low power port bu40ns like to scratch discs with low power
flojo
#20 Post by flojo » Sat Nov 09, 2024 10:52 pm
shisha0505 wrote: Sat Nov 09, 2024 10:03 pm ...a power supply?
What Billycar11 said is true, but for me it's because I use as few cheap multi-voltage adapters that I can with barrel adapters, similar to this: https://www.amazon.com/gp/product/B0CCN1QPY4
I also use C14 to C13+5-15R Y-splitters, which are pretty handy: https://www.amazon.com/gp/product/B0CB7GD658
#21 Post by d00zah » Sat Nov 09, 2024 11:05 pm
shisha0505 wrote: Sat Nov 09, 2024 9:48 pm ...
I've been pack-ratting hardware for decades. It supports current, as well as legacy interfaces. Plugs into a USB hub on my desk. & it looks 'pretty' :lol: & the old one it replaced didn't support ATAPI devices. It was time for an upgrade.
edit: Also, I have discovered the 'miniPC'... a NUC11 takes up virtually no space & is quite powerful for most of what I do. That adapter suited my purpose.
RibShark
#22 Post by RibShark » Tue Dec 10, 2024 10:56 am
In terms of cases for the slimline drives I have a ECD819-SU3 which seems to work very well on my BU40N and passes through all commands just fine. They seem to be available under a whole bunch of cheap brands.
#23 Post by Coopervid » Tue Dec 10, 2024 11:07 am
shisha0505 wrote: Sat Nov 09, 2024 9:24 pm i have more something like that on my mind
That slim adapter is OK if you can connect to a desktop SATA port. If not, buy this USB-> SATA adapter in addition. The Amazon link above for that adapter doesn't mention optical drives anymore. And - You need the power supply to make sure it works!
https://www.amazon.de/BENFEI-SATA-USB-K ... 9hdGY&th=1
Open the case and get the drive out. You don't need to break it. Most of the times the two housing halves just have snaps. But be careful.
shisha0505
#24 Post by shisha0505 » Thu Dec 12, 2024 12:01 am
thanks,
i know that i don't have to break the case to open it.
in the meanwhile i bought a 7-Pin SATA to Slim-SATA cable. something similar to this:
https://www.delock.de/produkt/84790/merkmale.html
I connected my drive directly to the mainboard an was able to flash it.
