fast forward and chapter with mkv playback
scuba
#1 Post by scuba » Wed Oct 05, 2011 1:42 pm
Hi Guys,
Make Mkv is great and and my playback is fine.
The problem i have is that my Samsung bd player (playing fromm hdd via usb) is unable to fast forward or chapter jump etc.
It can play or pause only.
I can convert a blu ray file to mkv with other programs and it works fine.
I would prever to stick with make mkv.. is anyone familiar with this issue and can it be fixed with make mkvs own settings?
cheers
boe_d
Re: fast forward and chapter with mkv playback
#2 Post by boe_d » Tue Feb 14, 2012 4:14 pm
scuba wrote:Hi Guys,
cheers
I have the same issue with my Oppo BR player. I convert with handbrake and the chapters work fine. I like MakeMKV a lot - but the chapters not working is the only major drawback. I would definitely use MakeMKV again once they fix that.
enitlas
#3 Post by enitlas » Tue Feb 28, 2012 10:00 pm
I had the same problem, run the mkv file through a program called mkvmerge GUI. get it here http://www.videohelp.com/tools/MKVtoolnix
Add the file go to muxing and add the command line options and select clusters in meta seek, this should fix the problem. Takes about 15 mins
celavey
#4 Post by celavey » Wed Mar 07, 2012 8:09 am
Is it also possible to play multiple movies continuously? Like if you have part1, 2, 3 and so forth.. Is it?
