ASUS drive given up the Ghost.
beamer
Post by beamer »
Hi my Asus Deive has stopped working at random times, it’ll load a 4K fine and start to convert but stops at random points and then won’t recognise the disc until it’s ejected and reloaded. Then it’ll do the same but at a different position on the disc. I have tried it a different computer, with a fresh install of win 10, different firmware with the same results.
I can only assume the drive is toast and I’m going to need a new one.
My question is what’s best and where to get one from that’ll work.
Cheers.
Re: ASUS drive given up the Ghost.
beamer wrote: Thu Nov 07, 2024 5:46 pm Hi my Asus Deive has stopped working at random times, it’ll load a 4K fine and start to convert but stops at random points and then won’t recognise the disc until it’s ejected and reloaded. Then it’ll do the same but at a different position on the disc. I have tried it a different computer, with a fresh install of win 10, different firmware with the same results.
Cheers.
Pioneer drives are recommended. Check out the sellers forum. viewforum.php?f=20
beamer
Post by beamer »
MartyMcNuts wrote: Fri Nov 08, 2024 10:56 pm
Cheers.
Thanks. I e looked in the sellers forum and got lost with what’s available.
beamer wrote: Sun Nov 10, 2024 1:18 pm
Cheers.
Post your country of residence and tell us if you want a full size or slim drive.
