Cast Away
Sekkyo
Cast Away
#1 Post by Sekkyo » Tue Oct 04, 2011 5:29 am
This disc is brand new, so I imagine all of these errors are copy protection related. MakeMKV claims the disc is supported by AACS v4, BD+ v2007.7. What can I do to help you allow me to rip something I own?
OS device name: /dev/rdisk3
Product: BDDVDRW CH08LS10
Revision: 1.00
Serial number: POOOOOOOOOO
Firmware date: 2009-01-15 12:34:56
Disc Information
Data capacity: 46.61 Gb
Disc type: BD-ROM
Number of layers: 2
MakeMKV v1.6.15 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/yo/MakeMKV_log.txt
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-867 HA13" opened in DASPI v1.3 mode.
Optical drive "BD-ROM HL-DT-ST BDDVDRW CH08LS10 1.00" opened in DASPI v1.3 mode.
DEBUG: Code 101016576 at ro;E]7DdP!D6bP/-qF:29395678
DEBUG: Code 101016576 at ro;E]7DdP!D6bP/-qF:121262049
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CH08LS10 1.00' at offset '25024659456'
Here's the debug log when I attempt to backup the disc:
Debug log started at Tue Oct  4 05:27:57 2011 , written by MakeMKV v1.6.15 darwin(x86-release)
001005:0000 MakeMKV v1.6.15 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/yo/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL MATSHITA DVD-R   UJ-867 HA13" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-ROM HL-DT-ST BDDVDRW CH08LS10 1.00" opened in DASPI v1.3 mode.
001003:0020 DEBUG: Code 2 at <:t0Gz~y>d}Ti4pu:121268719
001003:0020 DEBUG: Code 101016576 at ro;E]7DdP!D6bP/-qF:29395678
001003:0020 DEBUG: Code 101016576 at ro;E]7DdP!D6bP/-qF:121262049
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CH08LS10 1.00' at offset '25024659456'
005072:0000 Backing up disc into folder "/Volumes/Wheeeeee/CASTAWAY"
DAFD=PAAAADAAAAEABDQUEAQEBATJIQjAwMzQgAQoADEZEQwA=
DCE=mbtfglusf+6CS03kYQQeTZo9kCYd4pFw3zWDfj1yVd2GVDmF5VfsapDjzpnC74buKtxSE+cLZ/XgSaj1JHKk4t9ZT/7Hu/4NbuHL+4d9Nv155TCF3A0iYOQ1E/a7Pn2tdCVwdnRRm7JSgr7PckJT7pN+rZfrqdbEew==
003317:0000 Loaded 20 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00003.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
001003:0020 DEBUG: Code 101016576 at ro;E]7DdP!D6bP/-qF:213132629
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/BACKUP/index.bdmv' at offset '0'
001003:0020 DEBUG: Code 0 at r]|XQc7$4wutnw?(Sme-:213134377
001003:0020 DEBUG: Code 0 at r]|XQc7$4wutnw?(Sme-:29404878
001003:0020 DEBUG: Code 0 at r]|XQc7$4wutnw?(Sme-:121274101
005069:0080 Backup failed
005080:0204 Backup failed.
crowfax
Re: Cast Away
#2 Post by crowfax » Tue Oct 04, 2011 4:34 pm
Bad disc or failing drive.
Sekkyo
Re: Cast Away
#3 Post by Sekkyo » Wed Oct 05, 2011 1:56 am
Drive has only been through ~100 discs, disc is brand new. I'll keep at it, thank you for you response. Has anyone else had luck ripping this?
crowfax
Re: Cast Away
#4 Post by crowfax » Wed Oct 05, 2011 5:56 am
That error means it can't read the disc. There are no copy protections that can cause that.
Bad disc, or failing drive.
