Pioneer BDR-UD03 UHD possibility
Audiophilus
Re: Pioneer BDR-UD03 UHD possibility
I just discover this wonderful site.
I have a Verbatim drive, and with the makemkv software discovered in fact that it is a Pioneer drive
here is the information, if it is possible to have the firmware I will be very happy
Informations lecteur
Nom du lecteur SE : G:
Fabricant : PIONEER
Produit : BD-RW BDR-UD03
Révision : 1.14
Numéro de série :
Date micrologiciel : 2020-06-15
Marqueurs d'encryptage bus : 1B
Drive platform: RS8511
Firmware version: 1.14
Many thanks in advance
Fabricant : PIONEER
Révision : 1.14
Numéro de série :
fly1337
Hi all, same issue over here.
MKV Information:
MKV Information:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
londomollari
Hi there, got that same model and UHD "no disc inserted" issue as well, hoping for some help!
OS device name: E:
Revision: 1.14
toochu
Hello, could you help me please?
OS device name: E:
Revision: 1.14
Serial number:
PM is coming.Audiophilus wrote: Wed Nov 06, 2024 6:59 am Hello,
Fabricant : PIONEER
Révision : 1.14
Numéro de série :
PM is on its way.fly1337 wrote: Wed Nov 06, 2024 6:24 pm Hi all, same issue over here.
MKV Information:
Revision: 1.14
PM is coming.londomollari wrote: Thu Nov 07, 2024 6:36 pm Hi there, got that same model and UHD "no disc inserted" issue as well, hoping for some help!
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: [redacted] Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
PM is coming.toochu wrote: Fri Nov 08, 2024 4:08 pm Hello, could you help me please?
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
PM is coming.Gatsusan wrote: Mon Oct 28, 2024 6:12 pm hello,
can you please help me with the following drive?
Revision: 1.14
Serial number: ..........
Highest AACS version: 76
Check your PM.stryba wrote: Tue Oct 29, 2024 12:14 pm I would appreciate it, if you could help me, too. Please find drive information attached, thank you in advance and kind regards.
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: ******* Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Gronda
Another request for this, please.
OS device name: E:
Revision: 1.05
Serial number: QBDL090470WL
Firmware date: 2015-11-24
Drive platform: RS8510
Firmware version: 1.05
Unrestricted read speed: Yes-
PM sent.Gronda wrote: Sat Nov 09, 2024 2:16 pm Another request for this, please.
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.05 Serial number: QBDL090470WL Firmware date: 2015-11-24 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.05 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
paeron
Hello, could you please help? Thank you.
OS device name: /dev/sr1
Revision: 1.14
Serial number:
Highest AACS version: 75
PM sent.paeron wrote: Sun Nov 10, 2024 3:50 am Hello, could you please help? Thank you.
Revision: 1.14
Serial number:
lolhens
Hi Coopervid, could you help me out?
lolhens wrote: Sat Oct 05, 2024 1:17 pm Laufwerksinformation
OS-Gerätename: D:
Aktuelles Profil: DVD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: [redacted]
Firmware-Datum: 2020-06-15
