I am just wondering if there is a way to make MakeMKV recognize when a new disc is inserted in the discdrive WITHOUT having to restart the application. If i select "Select disc" the it just goes straigt to the mkv-ripper (but it recognizes the new disc). Since I am doing backups of my discs I want the entire disc, not just the separate videofiles.
This is no major problem, just a small nitpick but it would be nice to not have to restart the application whenever a new disc is inserted.
Update when new disc is inserted
Re: Update when new disc is inserted
It should be default just make sure you click the ok pop up when the first disc is done then eject the disc and out a new one in
I do this every day with mine works fine if it's not working for you , you likely have a different issue any VMS or junk like that?
Do not click the optical drive icon!! Just wait and use the second icon for ripping to folder.magsol76 wrote: ↑Wed Nov 06, 2024 4:15 pmI am just wondering if there is a way to make MakeMKV recognize when a new disc is inserted in the discdrive WITHOUT having to restart the application. If i select "Select disc" the it just goes straigt to the mkv-ripper (but it recognizes the new disc). Since I am doing backups of my discs I want the entire disc, not just the separate videofiles.
