Thank you so much @Coopervid!!!! The drive is now able to read UHD discsCoopervid wrote: Mon Nov 04, 2024 9:55 amPM is on its way.r00t59 wrote: Sat Nov 02, 2024 10:06 pm Hi @Coopervid, can you please share instructions for flashing the following drive?
Drive Information OS device name: H: Manufacturer: PIONEER Product: BD-RW BDR-212D Revision: 1.02 Firmware date: 2022-03-16 Bus encryption flags: 13 Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.02/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Pioneer BDR-212DBK vs BDR-212V
Re: Pioneer BDR-212DBK vs BDR-212V
matthikins
Is this drive capable of UHD ripping, and if so can someone point me to the secret sauce?
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DCDL026103WL
Firmware date: 2022-05-31
Highest AACS version: 81
Firmware version: ID06
Revision: 1.02
Yeah just email me see belowmatthikins wrote: Wed Nov 06, 2024 5:04 pm Is this drive capable of UHD ripping, and if so can someone point me to the secret sauce?
Revision: 1.02
Hi @Coopervid,
I am not new to flashing drives, but I am new to Pioneer, is this unit flashable? Insight greatly appreciated.
- piomkv.jpg (59.38 KiB) Viewed 10067 times
PM is coming.Bluntman wrote: Thu Nov 07, 2024 12:06 am Hi @Coopervid,
Hi Coopervid, would you help me as well with fw and instructions to flash the following pioneer BDR-212V drive
OS device name: E:
Revision: 1.02
Serial number: DDDL026507WL
Highest AACS version: 68
Thank You
OS device name: E:
Revision: 1.02
Thank You
Sure. PM sent.gclm2002 wrote: Fri Nov 08, 2024 1:52 pm Hi Coopervid, would you help me as well with fw and instructions to flash the following pioneer BDR-212V drive
OS device name: E:
Revision: 1.02
Thank You
kingpinRPh
I had previously purchased a Pioneer BDR-212DBK and have received the firmware link from Coopervid for that drive. I have purchased another drive which is the Pioneer BDR-212V. Can I use the same firmware that I already have for the 212DBK to flash 212V to unlock UHD capabilities on the 212V? Is the firmware update the same for all 212 drives?
OS device name: M:
Revision: 1.02
Serial number:
OS device name: M:
Revision: 1.02
Serial number:
samekingpinRPh wrote: Mon Nov 11, 2024 8:38 am I had previously purchased a Pioneer BDR-212DBK and have received the firmware link from Coopervid for that drive. I have purchased another drive which is the Pioneer BDR-212V. Can I use the same firmware that I already have for the 212DBK to flash 212V to unlock UHD capabilities on the 212V? Is the firmware update the same for all 212 drives?
OS device name: M:
Revision: 1.02
Serial number:
Yes and yes.kingpinRPh wrote: Mon Nov 11, 2024 8:38 am I had previously purchased a Pioneer BDR-212DBK and have received the firmware link from Coopervid for that drive. I have purchased another drive which is the Pioneer BDR-212V. Can I use the same firmware that I already have for the 212DBK to flash 212V to unlock UHD capabilities on the 212V? Is the firmware update the same for all 212 drives?
OS device name: M:
Revision: 1.02
Serial number:
I've got a 212v on it's way. Help flashing this drive would be appreciated. Any advice?
Check your PM:abpcipmvp wrote: Mon Nov 11, 2024 5:10 pm Hello,
OldGreyBeard
Just got a BDR-212V.
Is this flashable to use Libredrive?
If so, what do I need to do next?
Thanks much!
OS device name: H:
Revision: 1.02
Serial number: [redacted]
Thanks much!
OS device name: H:
Revision: 1.02
you can email me or pm cooperOldGreyBeard wrote: Tue Nov 12, 2024 12:41 am Just got a BDR-212V.
Thanks much!
OS device name: H:
Revision: 1.02
OldGreyBeard
Thanks much! Will do.
