Pioneer BDR-212DBK vs BDR-212V
r00t59
Re: Pioneer BDR-212DBK vs BDR-212V
Post by r00t59 »
Coopervid wrote: Mon Nov 04, 2024 9:55 am
r00t59 wrote: Sat Nov 02, 2024 10:06 pm Hi @Coopervid, can you please share instructions for flashing the following drive?
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.02
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8F00
Firmware version: 1.02/ID61
PM is on its way.
Thank you so much @Coopervid!!!! The drive is now able to read UHD discs :)
matthikins
Post by matthikins »
Is this drive capable of UHD ripping, and if so can someone point me to the secret sauce?
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DCDL026103WL
Firmware date: 2022-05-31
Highest AACS version: 81
Firmware version: ID06
matthikins wrote: Wed Nov 06, 2024 5:04 pm Is this drive capable of UHD ripping, and if so can someone point me to the secret sauce?
Revision: 1.02
Yeah just email me see below
Bluntman
Post by Bluntman »
Hi @Coopervid,
I am not new to flashing drives, but I am new to Pioneer, is this unit flashable? Insight greatly appreciated.
Bluntman wrote: Thu Nov 07, 2024 12:06 am Hi @Coopervid,
PM is coming.
gclm2002
Post by gclm2002 »
Hi Coopervid, would you help me as well with fw and instructions to flash the following pioneer BDR-212V drive
OS device name: E:
Revision: 1.02
Serial number: DDDL026507WL
Highest AACS version: 68
Thank You
gclm2002 wrote: Fri Nov 08, 2024 1:52 pm Hi Coopervid, would you help me as well with fw and instructions to flash the following pioneer BDR-212V drive
OS device name: E:
Revision: 1.02
Thank You
Sure. PM sent.
kingpinRPh
Post by kingpinRPh »
I had previously purchased a Pioneer BDR-212DBK and have received the firmware link from Coopervid for that drive. I have purchased another drive which is the Pioneer BDR-212V. Can I use the same firmware that I already have for the 212DBK to flash 212V to unlock UHD capabilities on the 212V? Is the firmware update the same for all 212 drives?
OS device name: M:
Revision: 1.02
Serial number:
kingpinRPh wrote: Mon Nov 11, 2024 8:38 am I had previously purchased a Pioneer BDR-212DBK and have received the firmware link from Coopervid for that drive. I have purchased another drive which is the Pioneer BDR-212V. Can I use the same firmware that I already have for the 212DBK to flash 212V to unlock UHD capabilities on the 212V? Is the firmware update the same for all 212 drives?
OS device name: M:
Revision: 1.02
Serial number:
same
OS device name: M:
Revision: 1.02
Serial number:
Yes and yes.
abpcipmvp
Post by abpcipmvp »
I've got a 212v on it's way. Help flashing this drive would be appreciated. Any advice?
abpcipmvp wrote: Mon Nov 11, 2024 5:10 pm Hello,
Check your PM:
OldGreyBeard
Post by OldGreyBeard »
Just got a BDR-212V.
Is this flashable to use Libredrive?
If so, what do I need to do next?
Thanks much!
OS device name: H:
Revision: 1.02
Serial number: [redacted]
OldGreyBeard wrote: Tue Nov 12, 2024 12:41 am Just got a BDR-212V.
Thanks much!
OS device name: H:
Revision: 1.02
you can email me or pm cooper
OldGreyBeard
Billycar11 wrote: Tue Nov 12, 2024 6:00 am
Thanks much! Will do.
