staknhalo
#10426
Post
by staknhalo » Tue Oct 29, 2024 4:09 pm
RESET_9999 wrote: ↑Tue Oct 29, 2024 3:55 pm
No,
static DV metadata for a movie graded in the 1000-4000nits is not good and probably worse than static HDR10 because DV metadata is a lot more aggressive than HDR10 static curves.
For example if you have a 4000nits grade with a static 1000nits DV metadata. All the low-nits scenes will be darker and the brighter scenes will be more clipped than proper HDR10 metadata tone mapping curve. It's practically the same as making a DV P8 hybrid using two sources with different brightness, as shown here:
https://www.youtube.com/watch?v=236athosits
Those movies with static DV are not done properly and should be avoided...
Trap is done properly because the content is below the DV 100nits floor (min)
got it - so essentially as long as there's even just 'a little' data/grading in the L1 (as in native Trap and Longlegs) it's 'good' DV data - French Dredd still bad - thanks
Edit - I verify pre-aligned remuxes with the web source or different disc release just by quickly glancing at L1 which is why I wanted to be sure instead of aligning the web data to disc myself to be lazier lol
LV8HD
#10427
Post
by LV8HD » Tue Oct 29, 2024 4:48 pm
@RESET_9999 in the most recent update you introduced the possibility to measure brightness of an HDR10 video on a frame-by-frame basis, which, to me, seems the most correct approach. Does this mean the MadVR method is less accurate even with excluded letterboxes? does it work on a scene-by-scene basis?
#10428
Post
by RESET_9999 » Tue Oct 29, 2024 5:10 pm
LV8HD wrote: ↑Tue Oct 29, 2024 4:48 pm
good catch haha. I didn't mention it in the release note because it's soooooo slow that it's unusable. I practically wasted my time on this code but it is indeed a frame by frame analysis / plotting. It uses the same script that generates the maxcll/fall stats in (7-2) (7-1).
Madvr analysis is also frame by frame but because I use Dovi_tool to plot the data, the graph is shot by shot. It's still 100% accurate but the values are rounded shot by shot. MadVR overall should be more accurate too since it measure pixels perceptually while the other script just measures the pixels as they are without any restriction.
kazuma
#10429
Post
by kazuma » Thu Oct 31, 2024 5:17 pm
reset_9999, how did you find the PQ of the tenant with cm4.0?
LV8HD
#10431
Post
by LV8HD » Fri Nov 01, 2024 11:25 am
RESET_9999 wrote: ↑Tue Oct 29, 2024 5:10 pm
I see. Correct me if I'm wrong. MadVR measures pixels using perceptual quantization while the other script the raw data?
LV8HD
#10433
Post
by LV8HD » Sat Nov 02, 2024 5:03 pm
@RESET_9999 pushed by curiosity I decided to check what the fastest method of measuring HDR with excluded letterboxes was on my PC (MKV measurement vs. Cropped ProRes measurement). The winner ended up being MKV although I have a good CPU (AMD Ryzen 7 7700x), but that's not the point.
As soon as both measurements were done (same movie) I took a look at them expecting to see the same results, however, they differed of a couple of nits. Why is that?
MKV measurement
ProRes measurement
#10434
Post
by RESET_9999 » Sat Nov 02, 2024 6:45 pm
prores encode probably change the grain structure a little bit so small variation like that is normal
Thats surprising. On my i9 13900ks it's almost two times faster with prores.
daffie
#10435
Post
by daffie » Tue Nov 05, 2024 10:57 am
kazuma wrote: ↑Thu Oct 31, 2024 5:17 pm
Hi, how do you watch ''with cm4.0'' ?
By using the CPM build with the AM6B+ ?
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
TheEqualizer
#10436
Post
by TheEqualizer » Tue Nov 05, 2024 10:50 pm
RESET_9999 wrote: ↑Wed Oct 16, 2024 7:28 pm
maybe, I dont know. You can also demux with tsmuxer
I've done all sorts of tests with this German edition of the movie "Late Night with the Devil". I used mkvtoolnix, dovi_script, DGDemux, MakeMKV, the first three have a similar output, the last one does not output correctly, but if you compare the scene-cuts of all the options, but they do not match the scene-cuts of the EL layer extracted using tsMuxeR, does this mean that technically remux mkv 7Profile is not allowed?
EL_scene-cuts
MKVToolNix_DoVi-Script_DGDemux_scene-cuts
https://i.ibb.co/KrX9cbG/EL-PLOT.png
https://i.ibb.co/VBs1t5h/ST-DL-PLOT.png
#10437
Post
by RESET_9999 » Wed Nov 06, 2024 12:52 am
I dont know. I watched this one in Profile 8 without EL and everything was fine.
TheEqualizer
#10438
Post
by TheEqualizer » Wed Nov 06, 2024 5:40 am
RESET_9999 wrote: ↑Wed Nov 06, 2024 12:52 am
I'll tell you more, those who have already watched the remux in mkv 7p also did not see anything suspicious, so in the question I pointed out that technically it is still not correct and it is not allowed to make such remuxs. Perhaps if a
British UHD appears, things will be better on it.
#10439
Post
by RESET_9999 » Wed Nov 06, 2024 11:30 am
i dont know but my p8 remux is perfectly in sync with the BL scene cuts
#10440
Post
by RESET_9999 » Fri Nov 08, 2024 10:25 pm
TheEqualizer wrote: ↑Wed Nov 06, 2024 5:40 am
I had another look at this movie and indeed a P7 mux with dovi_tool or mkvtoolnix is still wrong.
The RPU extracted from tsmuxer demuxed hevc is fine though so a P8 rip works.
