LibreDrive for Pioneer drives
epriddy
Post by epriddy »
ok. So I returned the Pioneer and got an archon with this info here:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO7N1U94428
Bus encryption flags: 1F
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
I should be good to flash the firmware, correct? if so, how?
bultom
Post by bultom »
Hide your sn ;)
Firmware IS ok, just need to wait a kind dude to pm you, dont remember his nickname ( maybe coopervid)
epriddy wrote:
Thu Oct 31, 2024 8:32 pm
Revision: 1.02
This is a LG BU40N. Simply use SDFTool Flasher and flash it to BU40N 1.03-MK. You can leave it at that or then flash it to BU40N 1.00 for wider software compatibility, if you use ripping software other than MakeMKV.
Still_luv3DBD
Post by Still_luv3DBD »
Coopervid wrote:
Mon Sep 16, 2024 7:14 pm
kilolimaalpha wrote:
Mon Sep 16, 2024 5:38 pm
Can anyone let me know what I need to do for this so that it can be used for UHD discs? Looks like the firmware is before the encryption, but I still can't read UHD discs. - Thanks!
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Read your PM.
I'm having the same problem, what fixed yours?
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: BBDL042762WL
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8F00
Firmware version: 1.00/ID61
(Sorry, I don't understand how to use forums)
Still_luv3DBD wrote:
Mon Nov 04, 2024 9:07 am
OS device name: G:
Revision: 1.14
Serial number:
Read your PM.
Revision: 1.00
You have a PM.
Still_luv3DBD
Thank you so much
tranquilitybase
Post by tranquilitybase »
How do I get this drive to work with MakeMKV. LibreDrive status states "Possible, not yet enabled." Cheers.
OS device name: /dev/rdisk8
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number:
Firmware date: 2023-01-06
Firmware version: ID05
Last edited by tranquilitybase on Tue Nov 05, 2024 3:02 am, edited 1 time in total.
tranquilitybase wrote:
Tue Nov 05, 2024 1:04 am
Revision: 1.03
Serial number: CGDL014052UC
sorry to new return it
see below if you want a pioneer with old fw
tranquilitybase
Sorry I don't know what that means. I'm new to this. MakeMKV created a file and told me to send support@makemkv.com which I did.
tranquilitybase
I have a couple of older drives. The one I've been using and works very well is an ASUS SBW-06D2X-U. It wouldn't read the 4k discs though so I bought this Pioneer one, but it doesn't work with MakeMKV apparently. I'll see if I can return it.
Tue Nov 05, 2024 3:19 am
Post the Makemkv info for the ASUS.
lord_farfig
Post by lord_farfig »
Coopervid wrote:
Tue Nov 05, 2024 9:57 am
I picked up the same model drive recently, here's the info from MakeMKV.
OS device name: /dev/sr0
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: ADDL211420WL
Firmware date: 2017-04-18
Firmware version: ID22
Drive seems to work fine in Windows, but I don't want to buy a license for the system. Unfortunately, I'm having issues reading discs in Linux.
tranquilitybase
Manufacturer: ASUS
Revision: 1.10
Serial number:
Drive platform: RS8510
Firmware version: 1.10/ID22
Tue Nov 05, 2024 6:31 pm
Manufacturer: ASUS
Revision: 1.10
Serial number:
You have a PM.
lord_farfig wrote:
Tue Nov 05, 2024 1:52 pm
Manufacturer: ASUS
Revision: 1.10
PM sent.
