NO_ANSWER_FROM_MAKEMKVCON
HuginMunin
Post by HuginMunin » Fri Oct 25, 2024 7:16 am
Today i upgraded my makeMKV to 1.17.8 (Lubuntu 20.04.6, Kernel 5.13.0-35). After the update, i got following errormsg:
I did some search, found infos here, on Reddit and GitHub, but nothing that solves this (also did a reinstall n stuff).
Any suggestions here?
segfaulted
Re: NO_ANSWER_FROM_MAKEMKVCON
Post by segfaulted » Fri Oct 25, 2024 9:08 am
Try my setup process and see if that works: viewtopic.php?p=160864#p160864
Nuitarius
Post by Nuitarius » Mon Nov 04, 2024 10:01 pm
I had the exact same issue. Running Debian.
I followed @segfaulted's guide.
I was missing both GLIBC v2.33 and 2.34. So I ran the guide twice fully for both versions and am now up and running again. v2.40 is no-go.
run $makemkvcon to check which versions you are missing.
Thanks @segfaulted
Besides the process segfaulted described I had to install the following first
$apt-get install patchelf gawk bison
Marantz AV8802A, Emotiva XPA-2 GEN3, Emotiva XPA-4 GEN3, Emotiva XPA-5 GEN2
OPPO UD-203, NVIDIA Shield, Sonos Connect, Emby Movie server
2 B&W CM9, 1 B&W CMC2, 4 B&W CM5, 4 B&W CCM662, 1 Funk Audio 18.0
