Older Noob Seeking Basic Advice
Re: Older Noob Seeking Basic Advice
RobertMoo wrote: Sun Oct 20, 2024 2:51 pm I've never tried this before, but what about running the hard drive off another PC in my home network? Once I get it setup, could I play movies through my local wifi or would the access be slow to start and then possibly not smooth? I've never tried to access different hardware via my home network, but just curious if you know if this would work. The only purpose would be to eliminate the HDD noise (buy having it located in another room). My projector is already a little noisy when I'm not actually playing any audio through it.
Sure. At the most basic level, this is how Plex works, sending movies across your local network. The general rule of thumb is the more parts of your network that can be hardwired the better off you'll be.
RobertMoo wrote: Sun Oct 20, 2024 2:51 pm I'm having a little trouble with getting the right subtitles to display in English ONLY for the non-English parts, but I think I figured it out with help from a "Movie Subtitles" spreadsheet I found online which tells which audio tracks to use, when to enable disable "forced", etc. If you're aware of this spreadsheet, can you tell me if there's an updated version of it? I got mine indirectly through someone else's post.
Is there a similar type spreadsheet to identify which video tracks to use for specific movies? I think you said I can find posts of people discussing specific movies, but one spreadsheet with a database would sure be nice for quick reference, if it exists.
I'm not aware of a spreadsheet for forced subtitles. I am aware of https://thediscdb.com, although I don't know if forced subtitle tracks are called out as such. I use a tool called MediaInfo that shows a bunch of details about .mkv files, including a count of elements in a subtitle track. A movie might have a couple thousand elements in a subtitle track. A TV show is probably many hundreds. A forced subtitle track probably has less than 100. I always try to verify it by watching a relevant clip in the movie, but once I do, I name the track 'Forced' and set the 'default' and 'forced' flags to true in the .mkv file. The MKVToolNix tools are good for this. Setting the flags that way means my Plex plays those forced subtitle tracks by default. I don't have as much experience with VLC, but there's undoubtedly a way you can set the flags in a file so VLC does the right thing by default. If you figure out which track is which in MakeMKV, you can set a subtitle track's default or forced flag to true by highlighting the track and selecting MKV Flags in the properties section. Include a 'd' for setting default to true and/or an 'f' for setting forced to true.
RobertMoo
Post by RobertMoo »
dcoke22 wrote: Mon Oct 21, 2024 3:22 pm At the most basic level, this is how Plex works, sending movies across your local network. The general rule of thumb is the more parts of your network that can be hardwired the better off you'll be.
huh. Interesting. I think I'll look into Plex more as I thought this was an online server. It would be tough to use ethernet connection in my situation so I might be stuck with wifi.
Again, thanks for your time and offering such detailed feedback. I've read and re-read your posts a few times. I have been experimenting more and getting used to the software, including MKVToolNix, so I have a better idea what you're talking about in real world use. Your advice was spot on.
If not VLC, what player do you typically use?
Generally speaking, for a regular blu-ray, I compress it to a 10-bit, h.265, 4000 kbps average bit rate file using a two-pass encode using the x265 encoder. I do the audio conversions I spoke about earlier and in general I end up with about a 5GB file from a 30GB rip.
I finally got around to using Handbrake with your settings to reduce video down to about 11% of its original size. 2 hour movie took 2 hours (to the minute) to transcode, so at those settings it seems to be a 1:1 ratio for conversion time. I'm still experimenting to see what looks good on the big screen. One setting you didn't mention was framerate. Do you generally just leave framerate at default settings? (30, with "peak framerate" box checked) Other sources I read suggested matching the framerate to the framerate of the original video. Is there a reason to use "peak framerate" over "Constant framerate"?
I'm mostly using handbrake on MKV formated videos, but handbrake defaults to mp4. Does it matter? Should I keep them as MKVs or does mp4 offer advantages?
Also, you recommended 2 passes, but I only noticed the box for "Mult-pass Encoding." I watched it do 3. Is there a setting for only 2?
Those small file sizes are great, but any recommendations on what handbrake settings to use convert a video to about half it's original size? I'm running a few different scenarios so I can test and compare on the big screen. (hard drive is filling up faster than I expected!)
Can 3D blurays be ripped with MakeMKV? I researched a little, but it didn't seem like VLC could play them.
I know, I keep shamelessly asking more questions! If it's too much, don't feel obligated and just know I appreciate all the help you've already given.
segfaulted
Post by segfaulted »
I'll jump in and throw some of my own thoughts here.
RobertMoo wrote: Thu Oct 24, 2024 3:44 pm One setting you didn't mention was framerate. Do you generally just leave framerate at default settings? (30, with "peak framerate" box checked) Other sources I read suggested matching the framerate to the framerate of the original video. Is there a reason to use "peak framerate" over "Constant framerate"?
Those options might matter for things like older TV shows if they mix 24fps/30fps content resulting in variable framerates. For most movies, choosing either option should give the same result. I often use "Same as source" + "Peak framerate" since that should follow whatever the original video uses.
MKV has more versatility with what codecs it can carry, but compatibility will really depend what player device/software you use. MP4 is more compatible with various players, but conversely it supports certain types of standard codecs.
One good point of comparison is with subtitles. MKV allows subtitles to be packed independently from the video stream, allowing you to toggle on or off during playback. If you choose MP4, subtitles will either have to be permanently baked into the video, or excluded entirely.
You've also asked about 3D video, so this is a bit of a tangent... MP4 will not able to natively contain the MVC video stream used for the second eye. You would need to re-encode the 3D video into a side-by-side (or top-down) arrangement if you wanted to go with MP4. MKV allows you to keep the original 3D video data without having to re-encode, however the compatibility for that is also very dependent on what player you're using. Many users who save their remuxed 3D movies for use on a hardware player would use M2TS instead of MP4 or MKV.
In case the word is unfamiliar: remux (or remultiplex) means you repackage the video+audio streams into a different container format without re-encoding the video or audio data. That means there's no loss of quality, and it's relatively fast. Going from blu-ray -> MKV like what MakeMKV does, or doing MP4 <-> MKV without re-encoding are examples of remuxing.
Doing a bit of rough math here. Suppose you have a 30gb rip with one audio track. I'll guestimate the video is 90% of the filesize, so 27gb for video. You wanted to halve the size, so that'll be 13.5gb across a 2.3 hour movie (8300 seconds). You get 13500/8300 = 1.626 megabytes/sec, then multiply by 8000 to get kilobits/sec which is about 13000 kbps. That'd be the video's average bitrate to use in Handbrake.
I personally don't use multi-pass/avg.bitrate encoding. Instead, I go with "Constant quality" with RF 18 which yields pretty good quality while reducing the filesize, and finishes in less time.
Yes, MakeMKV can rip the frame-packed h264 + MVC video from a 3D blu-ray and store it in MKV. However, VLC has no support for MVC so you'll only get to view the h264 portion like a normal 2D movie.
If you want to watch a 3D blu-ray, I'd go with mpc-hc + lavfilters (with the MVC plugin) + madVR which will work on a Windows PC. If that's too inconvenient, I mentioned re-encoding the 3D video into side-by-side which can be done using the BD3D2MK3D toolkit. You can watch the resulting SBS encode as a normal video which will work on a 3D screen or even a VR headset.
Regarding frame rate in Handbrake, I think I'm usually at 60 FPS with Peak Framerate checked. With Peak Framerate checked, Handbrake uses the frame rate setting as an upper limit on FPS and below that level it does 'same as source'. The result is 99.9% of the time, my encodes are effectively 'same as source'. That behavior & interface is a little convoluted in my view, but that's how it is documented and how it works.
Handbrake Framerate Docs
Like segfaulted, I prefer the .mkv file format. It is more versatile and my playback setup can handle it just fine.
On my computer, I generally use MPV as my playback program. I do most of my work on a Macintosh, but (perhaps a bit ironically), I also do most of it via the command line. MPV is easy & quick to launch via the command line. I even run the command line version of Handbrake. There's nothing wrong with VLC; it is just my personal preference to use MPV.
I have almost no experience with 3D video.
Handbrake: Constant Quality vs Average Bit Rate
Regarding average bitrate or constant quality. If you read Handbrake's documentation, they're pretty clear about their preference for people using Constant Quality. It is probably a sensible default for most people. I have several friends who encode things that way and their output is reasonably good. I'm sure segfaulted's RF 18 videos look very good. I think Handbrake's default for 10-bit h.265 is RF 22. A setting of RF 18 is higher quality (again, Handbrake is counterintuitive here).
There's no perfect answer for transcoding videos to a smaller file size. By its very nature, you're making a tradeoff to get the smaller file size.
In your case, since you're willing to have larger files, I might try 10-bit h.265 multipass encodes at 8,000kbps or maybe 10,000kbps. I'd probably also try RF 20 and RF 18 and maybe RF 16 and RF 14 as well. My guess is you'd probably be hard pressed to tell the difference between any of them.
On occasion I find one my transcoded videos has some flaw that I have to fix by adjusting a setting and running it through Handbrake again. It is relatively rare; most of the flaws I notice are also in the blu-ray source material. (The Star Trek: Picard blu-rays are my current favorite blu-rays to hate because of the egregious color banding present on them.) The current encoding settings I use mean I rarely end up with a flaw, have good enough quality and small enough files. Having more bits or a higher quality RF setting would reduce the number of instances of transcoding induced flaws and improve the visual quality (perhaps beyond my ability to perceive) at the expense of larger file sizes.
Don't let anyone tell you you're doing it wrong. :) There's no way to prove one particular way is more correct than another.
This is why I keep my rips in addition to my transcoded output. Today, my playback devices can play h.265 content pretty well. 5 years (maybe longer) ago, h.264 content was the sweet spot. h.264 is still well supported, but one can get the same quality in a smaller file or higher quality in the same size file with h.265 today. In a few years time, it'll probably be AV1.
Unless I rebuy every movie I own as a 4K UHD (the number of copies of Star Wars that I own not withstanding), I'll probably be watching regular blu-rays for a long time. And I'll probably be transcoding them into the sweet spot for my playback system right up until the point where the file size doesn't matter.
RobertMoo
Post by RobertMoo »
I've been away, but I'm back and appreciate the reply, Segfaulted,
segfaulted wrote: Fri Oct 25, 2024 8:43 am I'll jump in and throw some of my own thoughts here.
Okay, I guess I can play around with it.
Good to know, but so far my play methods have been fine on VLC with .mp4 or .mkv. I don't use them much, but I agree having subtitles embedded is much better.
Hmm... I think I need to take time to research this more before commenting. I don't have or plan to get a lot of 3d titles, so I might just play them off the PS4 and forget about ripping backups. Just to be clear, I'm not planning to watch these with a VR headset, just on the big screen, so I don't understand why I would need to break it into split screen (side by side, up/down). I use the electronic glasses to view the video on a projector screen where, without the glasses, the image looks like it has a sort of shadow, but the screen isn't split. Again, I know I need to research more just to get a better grasp what you're getting at..
Okay, so bitrate is the thing to tweak. I'll play with it. Thanks.
mpc-hc? That's an application/player?
Yeah, I need to research this more and play with the software before asking more questions. Thanks very much for all the feedback.
RobertMoo
Post by RobertMoo »
Hi dcoke22. I've been away so sorry for the belated reply.
dcoke22 wrote: Sat Oct 26, 2024 2:41 pm Regarding frame rate in Handbrake, I think I'm usually at 60 FPS with Peak Framerate checked. With Peak Framerate checked, Handbrake uses the frame rate setting as an upper limit on FPS and below that level it does 'same as source'. The result is 99.9% of the time, my encodes are effectively 'same as source'. That behavior & interface is a little convoluted in my view, but that's how it is documented and how it works.
Great. Thanks for feedback and info to read.
Like you, .mkv seems the best for me and my needs. I'll check out MPV and see how it compares to VLC.
Good. Thanks for feedback. I'm still debating how much I want to mess with 3D and am still doing research.
Okay, I understand. Thanks for giving me more ideas about settings to try.
Good to know. As you told me early on Bluray looks very good and 4k isn't much of a step up just for the resolution alone. If what I come up with works on my setup with the projector, I'll be happy and remain happy with that regardless of what newer standards come into play.
Thanks again for all your feedback and patience. Thanks to you, I'm much better informed about this stuff since my OP.
Oh, I've had good luck ripping my collection, but I recently bought a NEW version of the 4k version of blade runner (1982), but when I use MakeMKV it fails. I've tried several times. The dvd has two large size titles when seem identical. No matter which one I choose to rip, it fails. This isn't a full log but there are several error messages which appear as one of the following two types:
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset .....
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading ...... at offset ......'
My research suggests these errors typically suggest damage to the disc itself, although to my eye, there doesn't seem to be any physical problem. I bought it via ebay from Gruv where the seller has a good rating, but when I looked on their non-ebay website, I now see they have a bad rating, including reports of them selling used titles as new. I can rip other 4k titles no problem so the player seems fine. Again, I bought it new so I'm hoping I can send it back for an exchange, but any insight on the error messages? If it's not the physical disc itself, could it be MakeMKV is having trouble with it because it's a new 4k possibly with different protection? I'm not sure when it was manufactured, just that it arrived new wrapped in plastic in the usual way.
Those kind of errors indicate that the drive is having trouble reading spots on the disc. The standard advice is to gently clean the disc, even if it is brand new. Sometimes even brand new discs can have an almost invisible film on the data side of the disc. Folks here on the forum speculate it could be left over lubricants from the manufacturing process that didn't get properly washed off or deposits from the plastic case off gassing.
If you're experiencing rip errors, please read here first!
RobertMoo
Post by RobertMoo »
Been a while since I last posted. I've read through this whole thread a few times now. I've got a good collection going now.
Special thanks to dcoke22 for all the help and patience. Might be a while before I'm back this way again but I just wanted to say how much I appreciate all the helpful and detailed advice I got here.
Happy Holidays!
