Hi guy's, just wondering which App do you guys use to convert M2TS file ripped by MakeMKV to Convert to MKV file format?
i am using a Windows 11 Pro 64Bits Desktop.
Just need a Simple App, M2TS converter to MKV so that i can load up the files into my Synology NAS.
M2TS to MKV Conversion
Re: M2TS to MKV Conversion
So why do you rip to M2TS instead of MKV directly?Yethidran wrote: Mon Nov 04, 2024 10:28 am Hi guy's, just wondering which App do you guys use to convert M2TS file ripped by MakeMKV to Convert to MKV file format?
You can use Handbrake but make sure you set the Video and Audio options correctly.
MKVToolnix might be easier.
i cant seem to find the option in MakeMKV to do the "MKV" import..
All i see is the "BackUp option in Make MKV to back up to M2TS"
its confusing. i am confused..
No. Don't create folder backups but rip the disc to MKV directly. Insert your disc and click the big optical drive in Makemkv.
Oh My! You are Spot On!!
i didnt even realize that there was an option to click on the big optical drive..
thank you very much buddy!!
Cheers!!
Cheers!!
Yeah! Sometimes we can't see the forest for the trees.
your a life saver!!
i have been so busy backing up discs into M2TS all this while!!
time to delete it all and do the MKV Backup!
So much of time wasted and HDD space too..
Hahahaha!!
Hahahaha!!
You dont need to redo them from disc and out more wear on your disc drive.Yethidran wrote: Mon Nov 04, 2024 11:53 am your a life saver!!
Hahahaha!!
In makemkv do open files and select the index file under bdmv and you can makemkv from that very quick
