M2TS to MKV Conversion
Yethidran
Post by Yethidran »
Hi guy's, just wondering which App do you guys use to convert M2TS file ripped by MakeMKV to Convert to MKV file format?
i am using a Windows 11 Pro 64Bits Desktop.
Just need a Simple App, M2TS converter to MKV so that i can load up the files into my Synology NAS.
Re: M2TS to MKV Conversion
Yethidran wrote:
Mon Nov 04, 2024 10:28 am
So why do you rip to M2TS instead of MKV directly?
You can use Handbrake but make sure you set the Video and Audio options correctly.
MKVToolnix might be easier.
Yethidran
Post by Yethidran »
i cant seem to find the option in MakeMKV to do the "MKV" import..
All i see is the "BackUp option in Make MKV to back up to M2TS"
its confusing. i am confused..
No. Don't create folder backups but rip the disc to MKV directly. Insert your disc and click the big optical drive in Makemkv.
Yethidran
Post by Yethidran »
Oh My! You are Spot On!!
i didnt even realize that there was an option to click on the big optical drive..
thank you very much buddy!!
Cheers!!
Yeah! Sometimes we can't see the forest for the trees. :D
Yethidran
Post by Yethidran »
your a life saver!!
i have been so busy backing up discs into M2TS all this while!!
time to delete it all and do the MKV Backup!
So much of time wasted and HDD space too..
Hahahaha!!
Yethidran wrote:
Mon Nov 04, 2024 11:53 am
your a life saver!!
Hahahaha!!
You dont need to redo them from disc and out more wear on your disc drive.
In makemkv do open files and select the index file under bdmv and you can makemkv from that very quick
