Issues reading newer 4k titles - LG wp50nb40
jarardian
Post by jarardian »
Has anyone else experience read issues with the LG wp50nb40 with newer 4k titles? I've had issues with Criterion's Citizen Kane and Raging Bull 4k, as well as the new 4k release of The Man in the Iron Mask. I've tested all of these in a buddy's PS5, and all play without any problems.
The Man in the Iron Mask and Raging Bull won't show up at all, Citizen Kane rips until halfway through and then gets an 2 OS errors that the device does not exits & the volume for a file has been externally altered.
The disks and laser are perfectly clean, and I've been able to successfully scan other 4k and HD titles since. Additionally, I've only been using this drive for about 6 months, so I wouldn't expect wear and tear to be a factor at this point.
I'm also aware the Criterion 4k Citizen Kane release had manufacturing issues upon release, but I've confirmed that my disk was not one of the batches affected.
I also see now that the seller on here that I bought the drive from is no longer recommending this drive for purchase. Is there an issue with this drive I'm not aware of?
Much thanks for y'all's help!
Re: Issues reading newer 4k titles - LG wp50nb40
The drive disappearing in the middle of a rip is a classic sign that the drive is not getting enough power. If I recall correctly, the LG wp50nb40 is a USB powered drive. Be sure to plug in both plugs (if using the USB Y-cable) to high powered USB ports. A powered USB hub or ports directly on your motherboard are likely to work best.
jarardian
Post by jarardian »
That did fix the issue with Citzen Kane, but The Man in the Iron Mask and Raging Bull both still don't show up at all. At least that's one issue fixed, thank you!
LordJZS
Post by LordJZS »
Trying to get the The Criterion Collection "Raging Bull" 4K to work. (The drive is also fairly new. and the HD version worked and like 10 other movies) These are my specs and the error that i encountered. It does a thing too where it shuts my drive down and i have to restart it. I maybe get 40% of the way through and it fails no matter what i try. Please Assist.(I could not make a new post so I'm responding here hoping its relevant.
Product: BD-RE WH16NS60
Revision: 1.02
Serial number:
Highest AACS version: 81
Firmware version: 1.02
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '30802704384'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '30802704384'
Failed to save title 0 to file C:/Users/........“RAGING BULL”_t00.mkv
0 titles saved, 1 failed
