Pioneer BDR-206 + BDR-207 (D-/EBK)
zittrig
Post by zittrig »
Generally asked:
Is the BDR-208 the lowest modell number, which can be flashed to 4K compatibility with e.g. Billy's tools?
Or is there a solution for 206/207 also?
Re: Pioneer BDR-206 + BDR-207 (D-/EBK)
208 is the lowest that can do UHD
zittrig wrote: Sat Nov 02, 2024 11:12 am Generally asked:
Only 208 and higher.
zittrig
Post by zittrig »
Ok, thank you both!
