Criterion: 'Seventh Seal' and 'The Wages of Fear' No Audio
goingbust
Post by goingbust » Sun Oct 02, 2011 3:36 am
I know this was explained before as some sort of audio format that is not fully supported that a few publishers use. Can anyone point me to that explanation? Anyone know a workaround and which discs use this format? Thank you.
setarip_old
Re: Criterion: 'Seventh Seal' and 'The Wages of Fear' No Au
Post by setarip_old » Sun Oct 02, 2011 4:48 pm
Perhaps you can tell us exactly what audio format "THIS" is?
Post by SamuriHL » Sun Oct 02, 2011 4:55 pm
Looks like PCM mono. Do a search for LPCM and you'll find the posts.
Post by mike admin » Fri Oct 07, 2011 5:47 pm
LPCM mono IS supported in a "compatible" way. Please post mediainfo output for produced MKV file.
dpstjp
Post by dpstjp » Tue Oct 11, 2011 6:02 pm
Depends what you're playing it on. VLC will not play LPCM audio. However Dune HDI players do now play LPCM audio in MakeMKV files.
What you can do is use MakeMKV to make a file, demux the LPCM and convert to FLAC using ClownDB or HDStramextract and remux the FLAC back into the MKV file. I keep both LPCM and FLAC in my MKV files so that I can play either depending upon my setup.
Post by mike admin » Thu Oct 13, 2011 8:21 pm
dpstjp wrote:VLC will not play LPCM audio.
VLC will play LPCM as long as it's mono or stereo.
dpstjp
Post by dpstjp » Tue Oct 18, 2011 2:15 pm
mike admin wrote:VLC will play LPCM as long as it's mono or stereo.
I've always struggled with LPCM with my VLC. Here is the output from Mediainfo for my copy of Wages of Fear. The Video and LPCM were created using MakeMKV, the FLAC audio was added later. LPCM is silent on VLC, the FLAC works fine. Any thoughts welcome:
* * * MediaInfo Mac 0.7.36.0 file analysis report.
* * * MediaInfo Mac is ©2010 by Diego Massanti - http://mediainfo.massanti.com
* * * MediaInfoLib by Jerome Martinez - http://mediainfo.sourceforge.net
Created on: 18 Oct 2011 15:10:16 GMT+01:00
Report for file: Wages of Fear.mkv
General / Container Stream #1
Total Video Streams for this File.................1
Total Audio Streams for this File.................2
Total Subtitle Streams for this File..............2
Video Codecs Used.................................AVC
Audio Codecs Used.................................PCM / FLAC
SubTitle Codecs Used..............................S_HDMV/PGS / S_HDMV/PGS
Available Sutbitle Languages...................... / English
File Format.......................................Matroska
Play Time.........................................2h 28mn
Total File Size...................................29.1 GiB
Total Stream BitRate..............................28.2 Mbps
Encoded with......................................mkvmerge v4.9.1 ('Ich will') built on Jul 23 2011 17:10:39
Encoding Library..................................libebml v1.2.1 + libmatroska v1.2.0
Video Stream #1
Codec (Human Name)................................AVC
Codec (FourCC)....................................V_MPEG4/ISO/AVC
Codec Profile.....................................High@L4.1
Frame Width.......................................1 920 pixels
Frame Height......................................1 080 pixels
Frame Rate........................................23.976 fps
Total Frames......................................213133
Display Aspect Ratio..............................16:9
Scan Type.........................................Progressive
Color Space.......................................YUV
Codec Settings (Summary)..........................CABAC / 4 Ref Frames
Codec Settings (CABAC)............................Yes
Codec Settings (Reference Frames).................4
Video Stream Length...............................2h 28mn 9s 431ms
Video Stream BitRate Mode.........................VBR
Bit Depth.........................................8 bits
Video Stream Language.............................English
Color Primaries...................................BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer Characteristics..........................BT.709-5, BT.1361
Matrix Coefficients...............................BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio Stream #1
Codec.............................................PCM
Codec (FourCC)....................................A_PCM/INT/LIT
Audio Stream Length...............................2h 28mn 9s 425ms
Audio Stream BitRate Mode.........................CBR
Sampling Rate.....................................48.0 KHz
Bit Depth.........................................16 bits
Audio Stream Title................................LPCM 1/0
Audio Stream Language.............................French
Audio Stream #2
Codec.............................................FLAC
Codec (FourCC)....................................A_FLAC
Audio Stream BitRate Mode.........................VBR
Number of Audio Channels..........................1
Audio Stream Title................................FLAC
Audio Encoder.....................................reference libFLAC 1.2.1 20070917
Audio Stream Language.............................English
