LibreDrive for Pioneer drives
epriddy
ok. So I returned the Pioneer and got an archon with this info here:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO7N1U94428
Bus encryption flags: 1F
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
I should be good to flash the firmware, correct? if so, how?
Revision: 1.02
bultom
Hide your sn
Firmware IS ok, just need to wait a kind dude to pm you, dont remember his nickname ( maybe coopervid)
This is a LG BU40N. Simply use SDFTool Flasher and flash it to BU40N 1.03-MK. You can leave it at that or then flash it to BU40N 1.00 for wider software compatibility, if you use ripping software other than MakeMKV.epriddy wrote: Thu Oct 31, 2024 8:32 pm ok. So I returned the Pioneer and got an archon with this info here:
Revision: 1.02
Still_luv3DBD
I'm having the same problem, what fixed yours?Coopervid wrote: Mon Sep 16, 2024 7:14 pmRead your PM.kilolimaalpha wrote: Mon Sep 16, 2024 5:38 pm Can anyone let me know what I need to do for this so that it can be used for UHD discs? Looks like the firmware is before the encryption, but I still can't read UHD discs. - Thanks!
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: BBDL042762WL
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8F00
Firmware version: 1.00/ID61
(Sorry, I don't understand how to use forums)
You have a PM.Still_luv3DBD wrote: Mon Nov 04, 2024 9:07 amI'm having the same problem, what fixed yours?Coopervid wrote: Mon Sep 16, 2024 7:14 pmRead your PM.kilolimaalpha wrote: Mon Sep 16, 2024 5:38 pm Can anyone let me know what I need to do for this so that it can be used for UHD discs? Looks like the firmware is before the encryption, but I still can't read UHD discs. - Thanks!
OS device name: G:
Revision: 1.14
Serial number:
Revision: 1.00
Still_luv3DBD
Thank you so much
tranquilitybase
How do I get this drive to work with MakeMKV. LibreDrive status states "Possible, not yet enabled." Cheers.
OS device name: /dev/rdisk8
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number:
Firmware date: 2023-01-06
Firmware version: ID05
Revision: 1.03
Serial number:
Last edited by tranquilitybase on Tue Nov 05, 2024 3:02 am, edited 1 time in total.
sorry to new return ittranquilitybase wrote: Tue Nov 05, 2024 1:04 am How do I get this drive to work with MakeMKV. LibreDrive status states "Possible, not yet enabled." Cheers.
Revision: 1.03
Serial number: CGDL014052UC
see below if you want a pioneer with old fw
tranquilitybase
Sorry I don't know what that means. I'm new to this. MakeMKV created a file and told me to send support@makemkv.com which I did.
tranquilitybase
I have a couple of older drives. The one I've been using and works very well is an ASUS SBW-06D2X-U. It wouldn't read the 4k discs though so I bought this Pioneer one, but it doesn't work with MakeMKV apparently. I'll see if I can return it.
Post the Makemkv info for the ASUS.tranquilitybase wrote: Tue Nov 05, 2024 3:19 am I have a couple of older drives. The one I've been using and works very well is an ASUS SBW-06D2X-U. It wouldn't read the 4k discs though so I bought this Pioneer one, but it doesn't work with MakeMKV apparently. I'll see if I can return it.
lord_farfig
I picked up the same model drive recently, here's the info from MakeMKV.Coopervid wrote: Tue Nov 05, 2024 9:57 amPost the Makemkv info for the ASUS.tranquilitybase wrote: Tue Nov 05, 2024 3:19 am I have a couple of older drives. The one I've been using and works very well is an ASUS SBW-06D2X-U. It wouldn't read the 4k discs though so I bought this Pioneer one, but it doesn't work with MakeMKV apparently. I'll see if I can return it.
OS device name: /dev/sr0
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: ADDL211420WL
Firmware date: 2017-04-18
Firmware version: ID22-
tranquilitybase
Drive InformationCoopervid wrote: Tue Nov 05, 2024 9:57 amPost the Makemkv info for the ASUS.tranquilitybase wrote: Tue Nov 05, 2024 3:19 am I have a couple of older drives. The one I've been using and works very well is an ASUS SBW-06D2X-U. It wouldn't read the 4k discs though so I bought this Pioneer one, but it doesn't work with MakeMKV apparently. I'll see if I can return it.
Manufacturer: ASUS
Revision: 1.10
Serial number:
Drive platform: RS8510
Firmware version: 1.10/ID22
You have a PM.tranquilitybase wrote: Tue Nov 05, 2024 6:31 pmDrive InformationCoopervid wrote: Tue Nov 05, 2024 9:57 amPost the Makemkv info for the ASUS.tranquilitybase wrote: Tue Nov 05, 2024 3:19 am I have a couple of older drives. The one I've been using and works very well is an ASUS SBW-06D2X-U. It wouldn't read the 4k discs though so I bought this Pioneer one, but it doesn't work with MakeMKV apparently. I'll see if I can return it.
Manufacturer: ASUS
Revision: 1.10
Serial number:
PM sent.lord_farfig wrote: Tue Nov 05, 2024 1:52 pmI picked up the same model drive recently, here's the info from MakeMKV.Coopervid wrote: Tue Nov 05, 2024 9:57 amPost the Makemkv info for the ASUS.tranquilitybase wrote: Tue Nov 05, 2024 3:19 am I have a couple of older drives. The one I've been using and works very well is an ASUS SBW-06D2X-U. It wouldn't read the 4k discs though so I bought this Pioneer one, but it doesn't work with MakeMKV apparently. I'll see if I can return it.
Drive seems to work fine in Windows, but I don't want to buy a license for the system. Unfortunately, I'm having issues reading discs in Linux.Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: ASUS Product: SBW-06D2X-U Revision: 1.10 Serial number: ADDL211420WL Firmware date: 2017-04-18 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8511 Firmware version: ID22
