Help! DVD Region Blocked, Can’t Assign Region
Folan
Post by Folan »
Hello, I have "LG HL-DT-ST BD-RE WH16NS60 Blu-ray Drive" and I've used it hundreds of times ripping Blu-ray disks and one UHD Blu-ray, but this is the first time ripping a DVD disk and it keeps failing since it's a region locked DVD even though my drive is LibreDrive Enabled.
OS device name: F:
Current profile: DVD-ROM
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KL8M8AE5711
Highest AACS version: 75
Firmware version: 1.02
For some reason, it fails to read the DVD and keeps loading infinitely on Linux ripping machine on Docekr MakeMKV without giving any errors, So I tried to plug the drive into an Ubuntu Desktop machine it gave me a bunch of errors like:
Scsi error - ILLEGAL REQUEST:MEDIA REGION CODE IS MISMATCHED TO LOGICAL UNIT REGION
I then found out that LibreDrive Firmware should bypass region locks, but the drive should at least have any region, and mine isn't assigned to any, I tried using `regionset` command I kept getting `ERROR: Can't set region code.`, I think it could be due to not having the original firmware and linux not recognizing LibreDrive?
So I tried to plug it into a Windows 10 machine, and set the region to region 1 using DVD WinX and suddenly it magically started working
and MakeMKV were able to rip the DVD disks just fine.
I thought the issue was fixed but when I plugged it back into my Linux machine the problems were still happening, and still appears on Linux like it is not assigned to any region.
rip@ripping-machine:~$ regionset /dev/sr0
Current drive parameters for /dev/sr0:
  RPC Type: Phase II (Hardware)
  RPC Status: active region code (bitmask=0x00)
  Drive plays discs from this region(s): 1 2 3 4 5 6 7 8
  Vendor may reset the RPC 4 times
  User is allowed change the region setting 4 times
Would you like to change the region setting for this drive? [y/n]: y
Enter the new region number for your drive [1..8]: 1
new RPC bitmaks is 0xFE, ok? [y/n]: y
So I'm at the point where I can only rip the movie from my Windows machine for some reason, but not on my main Linux ripping machine.
Any Ideas?
