#1096
Post
by d00zah » Thu Oct 24, 2024 4:45 pm
ItsRawberry wrote: Thu Oct 24, 2024 1:48 pm
I did a quick search but didn't see this drive info come up for support. Here's my details:
OS device name: K:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: [redacted]
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 78
Firmware version: ID05
I currently cannot rip UHDs - any chance to get this drive supported?
Too new. Pioneer has deliberately crippled their drives for MakeMKV. Maybe, someday?
#1097
Post
by Coopervid » Thu Oct 24, 2024 9:02 pm
OS device name: K:
Revision: 1.03
Your drive's firmware is too new and can't be fixed.
muhul
#1098
Post
by muhul » Sun Oct 27, 2024 12:04 pm
Can anyone let me know what I need to do for this so that it can be used for UHD discs? Looks like the firmware is before the encryption, but I still can't read UHD discs. - Thanks!
OS device name: R:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number:
Firmware date: 2017-12-21
Drive platform: RS8601
Firmware version: E111/ID76
#1099
Post
by Billycar11 » Sun Oct 27, 2024 1:56 pm
muhul wrote: Sun Oct 27, 2024 12:04 pm
OS device name: R:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number:
Email me that info for a flash kit see below
Mike_Copy_Di
#1100
Post
by Mike_Copy_Di » Mon Oct 28, 2024 8:55 pm
Help for BDR-X13U??
OS device name: /dev/rdisk6
Product: BD-RW BDR-X13U
Revision: 1.04
Serial number: DDDL300587UC
Firmware date: 2023-08-01
Highest AACS version: 81
Firmware version: ID29
Disc Information
Label: LAST STARFIGHTER UHD
Timestamp: 2023-02-20 20:01:37
Protection: AACS2.0/C v77
Data capacity: 88.4 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
#1101
Post
by MartyMcNuts » Mon Oct 28, 2024 9:44 pm
Mike_Copy_Di wrote: Mon Oct 28, 2024 8:55 pm
Help for BDR-X13U??
Revision: 1.04
Disc Information
Number of layers: 3
Nope. Can't as the firmware is too new. Must be pre Dec 2022. Return it if you can!
wirrew
#1102
Post
by wirrew » Tue Oct 29, 2024 2:56 am
Hi, I bought a used ASUS SBW-06D2X-U that was already enabled for reading regular BDs, which works great.
However, it does not read 4K UHD discs, which I thought it would as it supports BDXL.
Can the drive be updated/modified to read UHD discs? The tech jargon on the forum is too much for me to comprehend
OS device name: G:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: [REDACTED]
Firmware date: 2017-04-18
Highest AACS version: 70
Drive platform: RS8510
Firmware version: 1.10/ID22
Many thanks in advance!
#1103
Post
by Billycar11 » Tue Oct 29, 2024 3:17 am
wirrew wrote: Tue Oct 29, 2024 2:56 am
OS device name: G:
Manufacturer: ASUS
Revision: 1.10
email me for the flasher see below
bultom
#1104
Post
by bultom » Tue Oct 29, 2024 6:27 am
I'm really angry with Pionner, I have a BDR S12 UHT
Received with 1.01 firmware and looked for firmware (2 years ago) it was 1.01, it's was great
Was patched for MakeMKV i was happy, then looked at pionner site to update it, descriptions of upgrades only mention "improve media compatibility" ok ...
Now it's on 1.04 and locked with encrypted firm ...
Bought a BU40N for 30 € but it was really a scandalous move from Pioneer to not tell firmware upgrade won't be revertable after 1.03 in patch note, and not telling firmware ware encrypted since 1.04 ..
Kept the drive in case some time it began able to do his job (and now i can't even just read BD UHD on PC like intel deprecated SGX instruction, i'm obliged to rip my BR with BU40N to read them even if i legally purchased them u_u
pipo233
#1105
Post
by pipo233 » Tue Oct 29, 2024 2:25 pm
@mike
I have a pioneer bdr-212-EBK with firmware 1.05.. You mentioned somewhere in this post that it might be possible to downgrade the firmware? If so how is that done?
- Screenshot_bdr-212m.png (77.49 KiB) Viewed 15881 times
And my second question is can my drive be added to libredrive, it states possible but not enabled.
I do have the following firmware's for this drive available (from pioneer):
BDR-212EBK_ULBK_FW101EU
BDR-212_ULBK_EBK_FW103EU
BDR-212_ULBK_EBK_FW104EU
BDR-212_ULBK_EBK_FW105EU
#1106
Post
by Coopervid » Tue Oct 29, 2024 2:30 pm
pipo233 wrote: Tue Oct 29, 2024 2:25 pm
@mike
No. This firmware after Dec. 2022 doesn't allow crossflashing.
pipo233
#1107
Post
by pipo233 » Tue Oct 29, 2024 3:40 pm
@coopervid
No means no downgrade possible?
Okay i'll understand that it is encrypted. My drive came with 1.05 so to bad.
But libredrive should be possible so i hope mike will/can add it?
Or will this never happen because of the encryption?
This is what mike said on page 4
Post by mike admin » Sun Feb 13, 2022 9:39 pm
andrewtjb wrote: ↑
Sun Feb 13, 2022 8:39 pm
You can't downgrade either as it just tells you your firmware is newer.
This could be (technically) bypassed. As of today there is zero need, but still...
#1108
Post
by d00zah » Tue Oct 29, 2024 4:11 pm
pipo233 wrote: Tue Oct 29, 2024 3:40 pm
@coopervid
andrewtjb wrote: ↑
All of which was superseded by
Pioneer firmware update February 2023, where Mike states:
As many of you have noticed, Pioneer released a mass firmware update for almost all drives. The firmware date is around December 2022 and release date is around February 2023. The sole purpose of this update is to disable LibreDrive and unofficial firmware flashing tools such as DVRtool.
epriddy
#1109
Post
by epriddy » Wed Oct 30, 2024 6:06 pm
I know these get repetitive, but this is the info for my pioneer drive.
Is is capable of being flashed so I can rip UHD movies?
OS device name: /dev/rdisk4
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: DGDL302104UC
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
Thanks in advance!
#1110
Post
by Billycar11 » Wed Oct 30, 2024 6:47 pm
epriddy wrote: Wed Oct 30, 2024 6:06 pm
Revision: 1.02
Thanks in advance!
Nah sorry man return it if you can the fw is to new
