Desync problem with "The Boy and the Heron" 4K blue ray
TedMosoly
Post by TedMosoly »
I bought italian version of "The Boy and the Heron" 4K Blue ray, when i RIP the disc with Makemkv 1.17.8 and there are those errors in output logs:
AV synchronization issues were found in file 'D://Il_ragazzo_e_l_airone_t00.mkv' (title #1)
AV sync issue in stream 6 at 0:00:00 : Forced subtitles track #6 turned out to be empty and was removed from output file
AV synchronization issues were found in file 'D://Il_ragazzo_e_l_airone_t01.mkv' (title #2)
2 titles saved
The audio and video plays fine. But the movie is 1 minute longer than the original duration, so there’s this extra minute at the end where nothing plays. I've tried several times, but the result is always the same.
Re: Desync problem with "The Boy and the Heron" 4K blue ray
Sync errors are common on things like forced subtitle tracks (rarely found). They're taken out when empty.
