XRTFORE External 4k Blu Ray Drive compatable?
SimHns1
Post by SimHns1 » Mon Oct 28, 2024 7:52 am
Hello
I recently purchased a drive a XRTFORE External 4k Blu Ray Drive. Which acording to MakeMKV is compatable for Libredrive however im not sure what firmwire to install and how to do so sfaely. there is no obviou BR number on the drive nor year it was Manufactured. Has anybody got this drive and managed to turn it into a Libredrive? If so any advice? Its very hard to find any information at all regarding this drive all i have to go off that its compatable is that it says it is on MakeMKV.
Re: XRTFORE External 4k Blu Ray Drive compatable?
Post by Billycar11 » Mon Oct 28, 2024 8:22 am
post your makemkv drive info section copy past the full thing
SimHns1
Post by SimHns1 » Mon Oct 28, 2024 8:50 am
Harware support: Yes
Firmware support: No
Firmware version: 0.BW42P
SimHns1
Post by SimHns1 » Mon Oct 28, 2024 8:51 am
Post by MartyMcNuts » Mon Oct 28, 2024 9:17 am
That's the LibreDrive Information. Also provide the Drive Information. (above the libredrive information, top right in MakeMKV)
SimHns1
Post by SimHns1 » Mon Oct 28, 2024 9:39 am
Manufacturer: hp HLDS
Product: BDRE BU40N
Revision: BW42
Serial number: 819CS001401
Firmware date: 2117-11-29 16:55
Bus encryption flags: 1F
Highest AACS version: 68
Post by Coopervid » Mon Oct 28, 2024 12:40 pm
Product: BDRE BU40N
Revision: BW42
Now follow this guide and use the SDFTool if you are on Windows.
viewtopic.php?f=16&t=19634
JonahParity
Post by JonahParity » Thu Dec 05, 2024 3:20 pm
Hi! I have purchased the same drive and am afraid to brick it. Was anyone able to find the exact correct firmware to flash for this drive?
Post by Billycar11 » Thu Dec 05, 2024 10:41 pm
Yeah remote flashed one of those before worked like normal guide see below you can diy or email me for it
mohrt
Post by mohrt » Fri Jan 24, 2025 3:39 pm
Here is an example of how I flashed this drive successfully, I used the BU40N 1.03 from the "all you need firmware pack":
./makemkvcon f -d '/IOBDServices/<device_id>' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
I've successfully ripped multiple Blu Ray 1080p and one 4k UHD so far no problems.
The firmware that shipped with this drive was encrypted: hp_HLDS_BDRE___BU40N_BW43_212011021415_7MEQVHAKKH81JD
