Can anyone let me know what I need to do for this so that it can be used for UHD discs? Looks like the firmware is before the encryption, but I still can't read UHD discs. - Thanks!
OS device name: R:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number:
Firmware date: 2017-12-21
Drive platform: RS8601
Firmware version: E111/ID76
muhul wrote: Sun Oct 27, 2024 12:04 pm
OS device name: R:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number:
OS device name: /dev/rdisk6
Manufacturer: PIONEER
Product: BD-RW BDR-X13U
Revision: 1.04
Serial number: DDDL300587UC
Firmware date: 2023-08-01
Highest AACS version: 81
Firmware version: ID29
Disc Information
Label: LAST STARFIGHTER UHD
Timestamp: 2023-02-20 20:01:37
Protection: AACS2.0/C v77
Data capacity: 88.4 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Mike_Copy_Di wrote: Mon Oct 28, 2024 8:55 pm
Help for BDR-X13U??
Revision: 1.04
Disc Information
Number of layers: 3
Nope. Can't as the firmware is too new. Must be pre Dec 2022. Return it if you can!
Hi, I bought a used ASUS SBW-06D2X-U that was already enabled for reading regular BDs, which works great.
However, it does not read 4K UHD discs, which I thought it would as it supports BDXL.
Can the drive be updated/modified to read UHD discs? The tech jargon on the forum is too much for me to comprehend
OS device name: G:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: [REDACTED]
Firmware date: 2017-04-18
Highest AACS version: 70
Drive platform: RS8510
Firmware version: 1.10/ID22
wirrew wrote: Tue Oct 29, 2024 2:56 am
OS device name: G:
Manufacturer: ASUS
Revision: 1.10
I'm really angry with Pionner, I have a BDR S12 UHT
Received with 1.01 firmware and looked for firmware (2 years ago) it was 1.01, it's was great
Was patched for MakeMKV i was happy, then looked at pionner site to update it, descriptions of upgrades only mention "improve media compatibility" ok ...
Now it's on 1.04 and locked with encrypted firm ...
Bought a BU40N for 30 € but it was really a scandalous move from Pioneer to not tell firmware upgrade won't be revertable after 1.03 in patch note, and not telling firmware ware encrypted since 1.04 ..
Kept the drive in case some time it began able to do his job (and now i can't even just read BD UHD on PC like intel deprecated SGX instruction, i'm obliged to rip my BR with BU40N to read them even if i legally purchased them u_u
I have a pioneer bdr-212-EBK with firmware 1.05.. You mentioned somewhere in this post that it might be possible to downgrade the firmware? If so how is that done?
And my second question is can my drive be added to libredrive, it states possible but not enabled.
I do have the following firmware's for this drive available (from pioneer):
BDR-212EBK_ULBK_FW101EU
BDR-212_ULBK_EBK_FW103EU
BDR-212_ULBK_EBK_FW104EU
BDR-212_ULBK_EBK_FW105EU
No. This firmware after Dec. 2022 doesn't allow crossflashing.
As many of you have noticed, Pioneer released a mass firmware update for almost all drives. The firmware date is around December 2022 and release date is around February 2023. The sole purpose of this update is to disable LibreDrive and unofficial firmware flashing tools such as DVRtool.
