Pioneer bdr 209 and Pioneer bdr 209m
cashkey1
#1 Post by cashkey1 » Sat Oct 26, 2024 3:49 am
hi, i have both these Pioneer drives.
wondering if i could crossflash it both to a different model so as to gain the uhd capability.
at the moment its both on official pioneer firmware 1.33
i downloaded dvrtool and dvrflash, but i really have no idea about using the "Cmd" tool.
what are the options to upgrade both these drives? can someone please help me? thanks in advance.
Re: Pioneer bdr 209 and Pioneer bdr 209m
#2 Post by Woodstock » Sun Oct 27, 2024 4:26 am
What does MakeMKV say about it's capabilities? A key is what firmware date it currently has. FW on or after 12/22/2022 is a no-go, as the drive is locked by Pioneer.
cashkey1
#3 Post by cashkey1 » Sun Oct 27, 2024 7:05 am
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.33
Serial number: [redacted]
Firmware date: 2015-12-09
Highest AACS version: 60
Drive platform: RS8600
Firmware version: 1.33
cashkey1
#4 Post by cashkey1 » Sun Oct 27, 2024 7:06 am
Revision: 1.33
Firmware version: 1.33/ID81
cashkey1
#5 Post by cashkey1 » Sun Oct 27, 2024 8:37 am
sorry bout the slow replies as my posts need to be approved by the Mod's..
#6 Post by Coopervid » Sun Oct 27, 2024 9:58 am
You need to post your Makemkv info for both drives. Especially I need to see Drive platform for both drives.
cashkey1
#7 Post by cashkey1 » Tue Oct 29, 2024 9:33 am
sadly, i am still waiting for the site admin or Moderaters to approve my posts...
malevolus
#8 Post by malevolus » Sun Nov 03, 2024 5:34 pm
OS device name: E:
Hi there, hope you don't mind me jumping on this thread as I've got the same question about my drive, I assume this is the info you need?
Revision: 1.34
Firmware date: 2016-04-25
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: 1.34/ID60
jabberwokki
#9 Post by jabberwokki » Sat Feb 22, 2025 11:00 am
hi all,
first time post thanks for having me 😊 hope this is the right place to put this post.
have aquired a Pioneer BDR-209EBK and am looking to make this 4K/UHD capable reading though the forum it appears this is possible but cant see which firmware ver to use,
have found all firmwares for the 209 via a polish site along with 211 firmwares if i understand this is the crossflash presume with DVRFLASH can any one advise ?
see below MKV drive info:
Revision: 1.34
Serial number: **********
Thanks in advance
Yethidran
#10 Post by Yethidran » Sat Feb 22, 2025 3:26 pm
i have 4 of the 209's. all are flashed and are now S11 drive's!! yahoo!!
209's are old but super now as they are S11 drive's!!
Yethidran
#11 Post by Yethidran » Sat Feb 22, 2025 3:30 pm
doesn't matter whatever word is behind the description of the 209 drives u have.
all will be flashed to the general s11 drives.
meaning they will become 211 drives. no more 209 drives!
209 to 211. simple as that.
yippee!!!
jabberwokki
#12 Post by jabberwokki » Sat Feb 22, 2025 3:57 pm
Thanks Yethidran,
so i can use DVRflash 2.75 with the force flash to change from current firmware(209 1.34) to 211 firmware ?
presume have to use the -ff command and flash with fw1.53 (as fw1.54 turns off libre and UHD), is that right? or should i be using a different firmware?
Yethidran
#13 Post by Yethidran » Sun Feb 23, 2025 1:30 am
i got them flashed with help from the helpful people here in makemkv.
i do not know how to use -ff command stuff sadly.
it all comes in a neat package called bdrflash with pdf instructions.
do get intouch with billycar11 or martymcnuts or coopervid.
GmanEst72
#14 Post by GmanEst72 » Sun Aug 10, 2025 8:52 am
Are you able to tell me if my Pioneer Pioneer BDR-209EBK, can be made to 4k / UHD compatible 209 to 211. Date on drive is Aug 2014 - So not sure if it can be flashed.
Here is the info I grabbed from MakeMKV.
Revision: 1.34
Serial number: **************
Thank you
#15 Post by Coopervid » Mon Aug 11, 2025 9:36 am
Revision: 1.34
Thank you
PM sent.
