I've been ripping the DVD to a local hard drive with AnyDVD & opening the ripped files up with MakeMKV. It's worked great 24 out of 25 times. Amityville Horror 2005 FF is crashing the program while reading the files. I was able to convert it to the .ts file type with tsMuxeR.
This program has lots of potential. I'm happy to be able to help troubleshoot. When it's completed I'll likely buy it.
I'm using the .mkv files with a Popcorn Hour NMT A-100. It's an improvement over using ISO files with the NMT. The .ts format works well too but no chapters in that file type, so .mkv is my preferred choice.
Here's the MakeMKV log;
Debug log started at Sat Sep 12 23:13:01 2009 , written by MakeMKV v1.4.6 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.6 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Rick/MakeMKV_log.txt
003006:000000:0000 Opening files on harddrive at E:/AMITY2005_FF/VIDEO_TS/
003002:003011:0010 Calculated BUP offset does not match one in IFO header.
003036:000000:0000 Title #0 was added (37 cell(s), 1:29:01)
003020:000000:0000 Title #1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001012:000000:0020 FAILURE: Code 0 at %7>'H}OW#;u6c|):213130835
003032:000000:0000 CellWallk algorithm failed (structure protection is too though?), trying CellTrim algorithm
Here's the Windows XP sp3 error report;
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="makemkvcon.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="libdriveio.dll" SIZE="15872" CHECKSUM="0xCCC01710" BIN_FILE_VERSION="1.4.6.0" BIN_PRODUCT_VERSION="1.4.6.0" PRODUCT_VERSION="v1.4.6_beta" FILE_DESCRIPTION="MakeMKV drive interrogation library" COMPANY_NAME="GuinpinSoft inc" PRODUCT_NAME="MakeMKV" FILE_VERSION="v1.4.6_beta" LEGAL_COPYRIGHT="Copyright (C) 2007-2009 GuinpinSoft inc" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1135F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.4.6.0" UPTO_BIN_PRODUCT_VERSION="1.4.6.0" LINK_DATE="07/30/2009 19:28:56" UPTO_LINK_DATE="07/30/2009 19:28:56" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="libmakemkv.dll" SIZE="158720" CHECKSUM="0x54BCFE36" BIN_FILE_VERSION="1.4.6.0" BIN_PRODUCT_VERSION="1.4.6.0" PRODUCT_VERSION="v1.4.6_beta" FILE_DESCRIPTION="MakeMKV multiplexer library" COMPANY_NAME="GuinpinSoft inc" PRODUCT_NAME="MakeMKV" FILE_VERSION="v1.4.6_beta" LEGAL_COPYRIGHT="Copyright (C) 2007-2009 GuinpinSoft inc" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2ADD5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.4.6.0" UPTO_BIN_PRODUCT_VERSION="1.4.6.0" LINK_DATE="07/30/2009 19:28:57" UPTO_LINK_DATE="07/30/2009 19:28:57" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="makemkv.exe" SIZE="2699264" CHECKSUM="0xDD2BB7A1" BIN_FILE_VERSION="1.4.6.0" BIN_PRODUCT_VERSION="1.4.6.0" PRODUCT_VERSION="v1.4.6_beta" FILE_DESCRIPTION="MakeMKV GUI application" COMPANY_NAME="GuinpinSoft inc" PRODUCT_NAME="MakeMKV" FILE_VERSION="v1.4.6_beta" LEGAL_COPYRIGHT="Copyright (C) 2007-2009 GuinpinSoft inc" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2A28ED" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.4.6.0" UPTO_BIN_PRODUCT_VERSION="1.4.6.0" LINK_DATE="07/30/2009 19:35:23" UPTO_LINK_DATE="07/30/2009 19:35:23" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="makemkvcon.exe" SIZE="2467328" CHECKSUM="0x79999589" BIN_FILE_VERSION="1.4.6.0" BIN_PRODUCT_VERSION="1.4.6.0" PRODUCT_VERSION="v1.4.6_beta" FILE_DESCRIPTION="MakeMKV console application" COMPANY_NAME="GuinpinSoft inc" PRODUCT_NAME="MakeMKV" FILE_VERSION="v1.4.6_beta" LEGAL_COPYRIGHT="Copyright (C) 2007-2009 GuinpinSoft inc" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x263C7D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.4.6.0" UPTO_BIN_PRODUCT_VERSION="1.4.6.0" LINK_DATE="07/30/2009 19:34:51" UPTO_LINK_DATE="07/30/2009 19:34:51" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="uninst.exe" SIZE="66312" CHECKSUM="0xF389A897" BIN_FILE_VERSION="1.4.6.0" BIN_PRODUCT_VERSION="1.4.6.0" FILE_DESCRIPTION="MakeMKV installer" COMPANY_NAME="GuinpinSoft inc" PRODUCT_NAME="MakeMKV" FILE_VERSION="v1.4.6_beta" LEGAL_COPYRIGHT="Copyright (C) 2007-2009 GuinpinSoft inc" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.4.6.0" UPTO_BIN_PRODUCT_VERSION="1.4.6.0" LINK_DATE="02/21/2009 19:46:34" UPTO_LINK_DATE="02/21/2009 19:46:34" VER_LANGUAGE="Language Neutral [0x0]" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="989696" CHECKSUM="0x2D998938" BIN_FILE_VERSION="5.1.2600.5781" BIN_PRODUCT_VERSION="5.1.2600.5781" PRODUCT_VERSION="5.1.2600.5781" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.5781 (xpsp_sp3_gdr.090321-1317)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFE572" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.5781" UPTO_BIN_PRODUCT_VERSION="5.1.2600.5781" LINK_DATE="03/21/2009 14:06:58" UPTO_LINK_DATE="03/21/2009 14:06:58" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
Best Regards,
RickL
MakeMKV crash reading ripped AMITY2005_FF
- Contact:
Re: MakeMKV crash reading ripped AMITY2005_FF
Thank you for providing all necessary information. The error was found and will be corrected in a next version.
Confirmed; MakeMKV_v1.4.8_beta_x86 converted AMITY2005_FF very well.mike admin wrote:Thank you for providing all necessary information. The error was found and will be corrected in a next version.
Great work
