sdf command does not give any output
maxreadyy
Post by maxreadyy » Sat Oct 26, 2024 6:23 pm
Hey there, I am working with a LG BH16NS55, trying to get from 1.05 to 1.02. I have everything installed on my Ubuntu machine and have problems with sdf.bin. When running
makemvcon f -d /dev/sr0 -f ./sdf.bin rawlash enc -i ./1.02.bin --verbose
, I only get "Loaded SDF.bin version 0x98" and then nothing. I waited for about 10 minutes, so I think there is something wrong here.
Thank you for your help!
Re: sdf command does not give any output
Post by dcoke22 » Sun Oct 27, 2024 7:13 am
Does your command really use 'rawlash' or is that a typo?
Kintsugisys
Post by Kintsugisys » Tue Nov 05, 2024 12:29 am
dcoke22 wrote: Sun Oct 27, 2024 7:13 am Does your command really use 'rawlash' or is that a typo?
I've been having the same issue. OP's typo aside, the system should be returning some kind of status. Instead it hangs forever I've been having the same experience under 1.17.8. I had to downgrade to 1.17.6 before I could flash my drive.
spkbd
Post by spkbd » Tue Jan 14, 2025 10:32 pm
Kintsugisys wrote: Tue Nov 05, 2024 12:29 am
Registered just to second this experience. I was able to flash drive when downgrading to 1.17.6, where 1.17.8 would just hang
