Dump Submitted - Deadpool and Wolverine 4K
JerichoJones
Post by JerichoJones »
I'm new. Don't hurt me.
I hashed (SHA-1) the INF and mine does not match.
MakeMKV v1.17.8 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\<username>/MakeMKV_log.txt
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Saved AACS dump file as C:\Users\<username>/.MakeMKV/MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_07FA.tgz
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213132721
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213131341
Re: Dump Submitted - Deadpool and Wolverine 4K
Your attached file was removed. Did you submit the file to svq@makemkv.com as requested, or did you assume it would get there eventually?
JerichoJones
The KEYDB update today has this disc.
