[FEATURE REQ / BUG?] makemkvcon accesses all optical drives no matter what is specified on the CLI to use
enigma_0z
Post by enigma_0z »
Title says it.
I have two optical drives hooked up to my system to rip more disks faster, and am working on a python script to automate importing data from my physical media to a storage server.
The (minor) problem is that when one drive is occupied ripping a disc and I load the other drive, both drives pause when a an instance of `mkmkvcon` is invoked while it reads both drives' properties. It'd be better optimized if, when `disk:n` or `dev:x` is specified on the CLI, only the specified drive is loaded/accessed.
Is this expected behavior, and if not, could it be added?
Re: [FEATURE REQ / BUG?] makemkvcon accesses all optical drives no matter what is specified on the CLI to use
I don't generally use MakeMKV from the command line, but in MakeMKV's preferences there's a setting called 'Ask for single drive mode' that makes an instance of MakeMKV only access one drive. With this turned on, you can run two instances of MakeMKV against separate drives and they won't interfere with each other. I do not know how this translates to the CLI.
enigma_0z
Post by enigma_0z »
I'll check it out and report back. From what I can tell, the cmdline version uses the same config file (I get debug logs even from `makemkvcon`, and same for reg), so hopefully it'll do a thing, thanks <3
drxenos
Post by drxenos »
Just use the --noscan option. I use 5 drives simultaneously from the command line (C++) and I don't have an issue.
