4k UHD not ripping
Cellis12
4k UHD not ripping
#1 Post by Cellis12 » Fri Oct 25, 2024 1:30 pm
Hi I am new to using Make MkV and for some reason all the 4k UHD disks that I have tried to rip have not been working. Standard bluray and dvd work just Not 4k UHD. So far I had tried 3 UHD disks and not one of them has worked. This is what it told me for Guardians of the Galaxy (and the other 2 UHD disks that I had try ripping) :
Saved AACS dump file as H://MKB20_v61_MARVEL'S_GUARDIANS_OF_THE_GALAXY_VOL_2_50BB.tgz
Using LibreDrive mode (v01.0 id=DFE22909F92F)
Downloading latest HK to H:/ ...
Automatic HK downloading is disabled or failed.\
If you can help me figure out what to do that would be much appreciated!
-Chris Ellis
Re: 4k UHD not ripping
#2 Post by Woodstock » Fri Oct 25, 2024 2:30 pm
This needs to be fixed first. Until you can download the HK file, there isn't a way to get new 4K content keys. There are several topics here on fixing that.
Cellis12
#3 Post by Cellis12 » Fri Oct 25, 2024 4:26 pm
Okay thankyou for that! I will do some more research on it.
