MakeMKV v1.17.6 darwin(arm64-release) started
Debug logging enabled, log will be saved as /Users/benherbert/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.00 MOBK8AA5020d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Title #00020.mpls has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00103.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/benherbert/Plex/Plex Queue
AV sync issue in stream 0 at 1:38:46.524 : video frame timecode differs by -20.859ms
AV sync issue in stream 0 at 1:38:46.566 : video frame timecode differs by -20.856ms
AV sync issue in stream 0 at 1:38:46.608 : video frame timecode differs by -20.854ms
AV sync issue in stream 0 at 1:38:46.649 : video frame timecode differs by -20.862ms
AV sync issue in stream 0 at 1:38:46.691 : video frame timecode differs by -20.859ms
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '57544409088'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '57544409088'
DEBUG: Code 1073741829 at Hh/5y8K"X{/3-9GyB[:213131502
DEBUG: Code 101000192 at Hh/5y8K"X{/3-9GyB[:213131502
DEBUG: Code 0 at T0mEpj]eJn>8)6`dHZf=:29395471
DEBUG: Code 0 at U*O3~7zwOyqrVvV@n:*&:29394068
DEBUG: Code 0 at T0mEpj]eJn>8)6`dHZf=:213131157
DEBUG: Code 0 at T0mEpj]eJn>8)6`dHZf=:121262647
DEBUG: Code 28097856 at T0mEpj]eJn>8)6`dHZf=:121261773
DEBUG: Code 0 at !Pz>4E#mN1ylR(J>Zl}F :213137068
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file /Users/benherbert/Plex/Plex Queue/Star Trek Beyond_t00.mkv
0 titles saved, 1 failed
