X-Men First Class Force Subtitles Hardcode in MKV
herbcheck
#1 Post by herbcheck » Fri Sep 23, 2011 4:10 am
Has any one successfully ripped Xmen with the correct subtitles to play during the video? I included the FORCED ones and they still don't show up. I want to put it on my iPad and they must be burnt in or I won;t know what is going on!
fr0z3ng33k
Re: X-Men First Class Force Subtitles Hardcode in MKV
#2 Post by fr0z3ng33k » Thu Sep 29, 2011 2:21 pm
I'm posting on this because I am curious as well. I want to be able to play it on my laptop.
Are you able to copy the disc to .mkv? It fails for me every time that I try (MakeMKV 1.6.15)
Also bringing this in from another post:
1.6.15 can't make a decrypted backup of X-Men First Class. It keeps failing when it gets to the digital copy files.
setarip_old wrote:Try the following:
1) Make an ENCRYPTED Full Disc copy to your hard drive (All files and folders, NOT an .ISO image file)
2) Delete the "DCOPY" (or whatever name is used) folder
3) Use this modified ENCRYPTED copy as your source for using MakeMKV to make a DECRYPTED Full Disc copy (By selecting "Open Files" and then selecting either "index.bdmv" or "MovieObject.bdmv" from the "BDMV" folder).
setarip_old
#3 Post by setarip_old » Fri Sep 30, 2011 2:32 am
@fr0z3ng33k
Thanks for quoting my post at ;>}:
http://www.makemkv.com/forum2/viewtopic ... 007#p16007
fr0z3ng33k
#4 Post by fr0z3ng33k » Fri Sep 30, 2011 4:24 pm
setarip_old wrote:@fr0z3ng33k
Your welcome, editing the post to include your name =).
herbcheck
#5 Post by herbcheck » Sat Oct 01, 2011 12:22 am
Use MKVtools click convert to MP4 and load the SRT file with the + function. Make sure to set the sub button to Hard (Burn) and not soft. Takes a while to re encode the MKV but worth it. THen convert in handbrake like usual!
