Archgon Flashing Issue (Model MD-8107-U3)
TheEvilMayor
Post by TheEvilMayor »
I recently bought a new Archgon MD-8107-U3 from Amazon to replace an older one that has started having mechanical issues. I'm attempting to flash it to BU40N-1.03 and am running into an issue. When I attempt to flash it, everything seems to work exactly how it should. Terminal shows the operation as having completed successfully, but the drive does not actually seem to have taken the 1.03 firmware.
I grabbed the latest sdf.bin before flashing, and the 1.03 firmware from Mike's link.
Here's what I'm seeing in the terminal:
KAA-WS14:~ nickkmet$ /Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -d HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO4N1U94846 -f /Users/nickkmet/Downloads/MakeMKV\ Backups/sdf.bin rawflash -i /Users/nickkmet/Downloads/MakeMKV\ Backups/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file /Users/nickkmet/Downloads/MakeMKV Backups/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO4N1U94846
yes
 100% Operation finished
Done successfully
When I open up MakeMKV, the drive still shows as being on the 1.02 firmware, and UHD discs will not rip. Any ideas?
Here's what MakeMKV shows:
Product: BD-RE BU40N
Revision: 1.02
Serial number: [redacted]
Bus encryption flags: 1F
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Re: Archgon Flashing Issue (Model MD-8107-U3)
Post by d00zah »
I believe your command line is missing 'enc'. Try:
/Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -d HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO4N1U94846 -f /Users/nickkmet/Downloads/MakeMKV\ Backups/sdf.bin rawflash enc -i /Users/nickkmet/Downloads/MakeMKV\ Backups/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
TheEvilMayor
Yup, that was it. Not sure how I missed that. Thank you!
