Tankerhank
Re: Pioneer firmware update February 2023
Post by Tankerhank » Mon Sep 30, 2024 4:59 pm
Billycar11 wrote: Thu Sep 26, 2024 8:14 pm
Return the pioneer it can't do UHD.
I have some pioneers with old fw if you want one see below.
The LG can be flashed see guide below or email me for a flasher
[/quote]
Thanks for the response ... after pondering on returning the Pioneer I decided being I can update the LG I will do that, and keep the Pioneer for other uses. Ya I know its a spendy drive for something that won't do the UHD, but it does blu-ray with MKV.
I will make contact with you for the flasher to get the LG out of the dark ages.
Thanks Again
Post by Billycar11 » Mon Sep 30, 2024 8:43 pm
Tankerhank wrote: Mon Sep 30, 2024 4:59 pm
Thanks Again
yeah but you still spent way more on a UHD pioneer for it not to do UHD might as well still return it and get a non UHD version then.
Xorshasia
Post by Xorshasia » Sat Oct 19, 2024 3:11 am
Is this still the case? Older Pioneer drive that you helped me flash to work finally bought the farm after ten years and won't read any discs anymore. Saw someone mention the Pioneer BDR-S13U-X, and saw it on sale at Amazon. Immediately bought it and installed it. Of course, first thing I notice is the message about LibreDrive being "Possible, not yet enabled" and a firmware of 1.05. I definitely have time to return it, as I just bought it yesterday. Though, I am hoping there's a light at the end of the tunnel.
Post by Billycar11 » Sat Oct 19, 2024 5:36 am
Xorshasia wrote: Sat Oct 19, 2024 3:11 am
sadly yes buy i still have some with old fw if you want one see below
GriffinJax
Post by GriffinJax » Tue Oct 22, 2024 8:58 pm
If this is to far off topic or out of place, I am sorry.
I'm curious if maybe you could disassemble and flash directly to the chip to down grade firmware on drives with newer firmware. though if the flash is BGA it could be tricky to accomplish and may not be worth it.
Does anyone have a drive they would be willing to take apart and post pictures of the board?
Post by Coopervid » Tue Oct 22, 2024 9:06 pm
GriffinJax wrote: Tue Oct 22, 2024 8:58 pm If this is to far off topic or out of place, I am sorry.
Forget that.
Post by Billycar11 » Tue Oct 22, 2024 9:32 pm
pretty much what cooper said its 128 pins not your normal 8pin bios chip
i sure only some of them are needed to flash fw but we don't know what ones those are and you would need to solder on atleast, or sometimes in circuit flashing does not work then it would require de soldering
GriffinJax
Post by GriffinJax » Tue Oct 22, 2024 9:49 pm
Coopervid wrote: Tue Oct 22, 2024 9:06 pm
Forget that.
Sure.
Billycar11 wrote: Tue Oct 22, 2024 9:32 pm
Not trying to step on any toes here.
I'm assuming since you stated its a 128 pin flash that there are pictures somewhere?
Post by Coopervid » Tue Oct 22, 2024 9:57 pm
GriffinJax wrote: Tue Oct 22, 2024 9:49 pm
Forget that.
Sure.
Boy. Forget it! I can recommend some drives that are still flashable.
Post by Billycar11 » Tue Oct 22, 2024 9:59 pm
already take these apart all the time here the chip pic and the rest of the board thats the best i could get of the etching its barely readable but you can get it i think it says "Renesas
R8j32740fp42"
https://imgur.com/a/EjLMMxr
GriffinJax
Post by GriffinJax » Tue Oct 22, 2024 10:05 pm
I have drives, that I have flashed and work great thanks to people like you on this forum.
I was just asking to see if anyone had looked into the hardware already. Ill order a drive tonight so i can get eyes on the flash.
Post by Billycar11 » Tue Oct 22, 2024 10:12 pm
GriffinJax wrote: Tue Oct 22, 2024 10:05 pm I have drives, that I have flashed and work great thanks to people like you on this forum.
might as well get one with old fw from me if you want to
GriffinJax
Post by GriffinJax » Tue Oct 22, 2024 10:14 pm
Billycar11 wrote: Tue Oct 22, 2024 9:59 pm
R8j32740fp42"
Thank you very much!
That at least gives me a head start. what drive model # is that exactly?
you wouldn't happen to have a picture of the top of the board??
Post by Billycar11 » Tue Oct 22, 2024 10:16 pm
GriffinJax wrote: Tue Oct 22, 2024 10:14 pm
i dont but there was not much of interest up there
it was an s13UBK
GriffinJax
Post by GriffinJax » Tue Oct 22, 2024 10:25 pm
Billycar11 wrote: Tue Oct 22, 2024 10:16 pm i dont but there was not much of interest up there
it was an s13UBK
Thank you Very much.
it gives me a place to start so I can dig through data sheets until a drive gets here.
