CSS Encrypted Backup to ISO for DVD and Bluray on Linux
Absolve6780
Post by Absolve6780 »
Hi all,
I wanted to find a method that works for both DVD and Blurays that allows for backing up / cloning on Linux with CSS intact. In MakeMKV, I see the decrypt checkbox checked (and unable to be unchecked) when I try to back up DVDs. For Blurays, that option can be toggled on and off in my experience. I am currently running either of the following:
dd if=/dev/sr0 bs=2048 count=xxxxxxx of=filename.iso
OR
ddrescue -b 2048 /dev/sr0 test2.iso
Both are readable in MakeMKV after they complete. Running a
diff file1.iso file2.iso
comes back empty. My questions are the following:
  • Which option is better?
  • Is there a command better suited for this?
  • Is this the best approach to clone all of your DVDs/Blurays digitally?
I would just like to have a 1:1 copy of the disk (Bluray and DVD), so I can burn it on a disk (DVD or Bluray) later on if/when disk rot hits the disks.
I would love any additional advice in this area as well.
