Pioneer BDR-212DBK vs BDR-212V
Re: Pioneer BDR-212DBK vs BDR-212V
Collision3147 wrote:
Tue Oct 22, 2024 1:41 am
Hi Coopervid,
I have the following drive:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number:
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 20
Firmware version: ID06
If there's a firmware or flasher available to enable UHD support, would appreciate the pointer (presumably via PM).
PM sent.
Remendado
Post by Remendado »
Hi Coopervid
I've just had to buy my first new Blu-ray drive in 13 years and found that the world has changed a lot since then, so that makes me in effect a newbie. I've bought a BDR-212V for its supposed improved burning abilities and now I need to persuade it to play DVD-RAMs, since I often help others transfer their old VHS tapes via RAMs burned on an almost equally old Panasonic DVD recorder.
OS device name: M:
Revision: 1.02
Serial number: {redacted]
Would you please send the file to make this possible (along with all the other advantages of cross-flashing)
Many thanks
Remendado wrote:
Wed Oct 23, 2024 6:18 pm
Hi Coopervid
OS device name: M:
Revision: 1.02
Many thanks
PM sent.
Remendado
Post by Remendado »
@Coopervid
The flasher worked like a dream. Thank you so much.
lordrobbi
Post by lordrobbi »
Hi @Coopervid,
I bought a Pioneer BDR-212DBK with a firmware dated 16.03.2022, so before December 2022. However, it has a different platform, not the MT1959, see below:
Product: BD-RW BDR-212D
Revision: 1.02
Serial Number: DADI....
Firmware Date: 2022-03-16
Bus Encryption Flags: 13
Highest AACS Version: 68
Drive Platform: RS8F00
Firmware Name: PIONEER BDR-212T
Firmware Type: Original (unpatched)
Firmware Version: 1.02/ID61
DVD All Regions: Yes
Read Raw BD Media: Yes
Read Raw BD Media Metadata: Yes
Unlimited Read Speed: Yes
Is there a way to flash the drive?
best regards
lordrobbi
lordrobbi
Post by lordrobbi »
Hello everyone,
the Pioneer BD-RW BDR-212D drive is currently available at Amazon.com for €98 including shipping. Mine has a firmware version dated 03-2022, with January 2024 on the outside of the case.
The delivery took 10 days.
Regards,
lordrobbi wrote:
Wed Oct 30, 2024 7:09 pm
Hello everyone,
Regards,
You are very lucky. Check your PM.
flojo
Post by flojo »
Coopervid, if these are flashable, could you please send the required tools?
FWIW, I bought 5 of these for a CDDA loader project and all are made in March 2024 and everything is identical besides the serial number.
Revision: 1.02
Serial number:
Highest AACS version: 72
flojo wrote:
Wed Oct 30, 2024 9:51 pm
Revision: 1.02
Serial number:
Vinpower 212V are not updated an still work. Check your PM:
lordrobbi
Post by lordrobbi »
Servus Coopervid,
it´s all fine - many Thanks! :mrgreen:
jakerto
Post by jakerto »
Coopervid can you please send me the file(s) to flash this drive?....thanks very much
Revision: 1.02
Serial number:
Highest AACS version: 81
jakerto wrote:
Sat Nov 02, 2024 2:45 am
Revision: 1.02
Serial number:
PM is coming.
r00t59
Post by r00t59 »
Hi @Coopervid, can you please share instructions for flashing the following drive?
OS device name: H:
Revision: 1.02
Firmware date: 2022-03-16
Highest AACS version: 77
Drive platform: RS8F00
Firmware version: 1.02/ID61
r00t59 wrote:
Sat Nov 02, 2024 10:06 pm
OS device name: H:
Revision: 1.02
Serial number: DADL055375WL
PM is on its way.
pacmansyu
Post by pacmansyu »
is it possible for this drive to rip uhd discs?
OS device name: E:
Revision: 1.02
Serial number:
Highest AACS version: 31
